- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
internet connection
I just hooked up the orbi in my house and its working for the 2.4 signal, but not the 5G signal. Also it is only working on some web sites and not other ones. It seems to be blocking the secure sites. I have a att&t modem and did a passthrough in the settings using the mac address of the orbi. I seem to be missing somthing else, but not sure what it is. Any help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: internet connection
Did you try a power OFF of the ISP modem and RBR after you configured the modems IP passthru for the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do you know the 5ghz isn't working?
The orbi uses bandsteering so devices are only going to see one SSID.
Are you using a wireless scanner to find out what's broadcasting and if so, what one is it?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
