× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Adding a satellite
Marienewbold
Follower
Adding a satellite
I have purchased an additional satellite for my RBR40 Orbi system. I cannot for the life of me get it to connect . I have two other satellites that work fine and came with the original router. One is connecting with a cable and one is used vis wifi. Why won’t this new one connect. It just keeps coming up with the purple ring late. I’ve tried moving it closer but still no link. I’ve tried adding on the orbi app but it’s not picking it up. Could it be a fault with the satellite.
Message 1 of 3
Guru
Re: Adding a satellite
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
Message 2 of 3
CrimpOn
Guru
I have had more success syncing satellites using the Orbi web interface (http://orbilogin.net) than with the Orbi 'app'.
Select the bottom menu item Add Orbi Satellite and follow the directions.
Since this unit was not part of the initial package, it would not hurt to do a Factory Reset on the satellite.
https://www.youtube.com/watch?v=cMw4ePACgc4
And, I would definitely do the initial setup in the same room as the router.  If it won't work there, it won't work anywhere.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 842 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
