- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Can't Connect Amazon Echo or Echo Dot To New Orbi Wifi..Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't Connect Amazon Echo or Echo Dot To New Orbi Wifi..Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I too recently bought the new wifi 6 router system and I am confused; didn't I just pay $700 for the AX features? Wouldn't disabling this just simply make it a non-wifi 6 router? I did try this solution and sure enough, it let me connect, but then I switched it back and it would no longer connect.
Help me understand if disabling AX does not impact performance?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@molson1020 wrote:I too recently bought the new wifi 6 router system and I am confused; didn't I just pay $700 for the AX features? Wouldn't disabling this just simply make it a non-wifi 6 router? I did try this solution and sure enough, it let me connect, but then I switched it back and it would no longer connect.
Yes, it's not ideal for you to disable AX on your new AX router and will impact performance for wifi 6 devices (like iPhone 11 Pro). Instead, first try setting CTS/RTS to 2347 in Advanced...Wireless Settings at http://orbilogin.com/start.htm This fixes some wireless compatibility issues with the Orbi AX.
See the Orbi AX forums for other threads specific to the AX systems: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- Mark as New
- Bookmark
- Subscribe
- Permalink
New Netgrear AC1200 with 3 satellites. Connected easily with Satellites, TVs, phones and iPads. Cannot connect with Alexia Ehco Dot. Get a message saying that my password is incorrect. What gives?
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
