Orbi WiFi 7 RBE973
Reply
Duplicate a RBK50 installed solution
JohnHighrock
Hello,
Already equipped with a rbk50 system (router + 1 satellite) I would like to extend my wifi coverage.
Can I install a second RBK50 system (router+satellite) with the same wifi name to make this extension.
Thank you 😉
Message 1 of 6
Guru
Re: Duplicate a RBK50 installed solution
You can install the RBS from the 2nd system. The RBR from the 2nd system can only work in router mode or in AP mode. Not as a satellite.
@JohnHighrock wrote:
Hello,
Thank you 😉
Message 2 of 6
JohnHighrock
I installed very Well the rbs satellite to my existing orbi network and it works fine 😉
My problem now is that I can’t erase the previois configuration of the second RBR.
The factory reset doesn’t works at all and I face the previous name and mainly the previous password…:-(
Message 3 of 6
Guru
Be sure your pressing the reset button in back for 15 seconds to effect a factory reset.
Message 4 of 6
JohnHighrock
Hi
I pressed for 15sec : nothing change
30 sec : nothing again
30sec then Power off then power on and 30 sec more : nothing again
Still the previous SSID name and password (not known 😞
So I’m stuck :-(((
Message 5 of 6
Guru
Try a 30-30-30 reset process. Be sure you follow the process correctly:
https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/orbi-rbr50-not-connecting-to-the-inte...
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 401 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
