- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware Version 1.10.1.2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anybody know what they fixed? All it has in the release notes is "fixed some bugs" That is not a release note. That is a joke.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware Version 1.10.1.2
It actually made my wifi completely unstable after the previous version fixed a lot of the issues i had been dealing with. Thankfully I still have some time left on my support, so so I've opened a ticket
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Through support I was able to get the new beta firmware and that seems to have fixed things. I am guessing the next public release isn't far away guessing on the comments their tech support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
LeBullet,
How were you able to downgrade the firmware and stop the unit from auto-updating to the latest? My unit was working perfectly before 1.10.1.2. and everytime I manually load the previous version it automatically updates itself in a matter of minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seemed I wasn't, the next day, it had auto updated itself and my issues have returned in earnest.
youd kind of hope they'll add this "check box ", wouldn't you
aG
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think it's worse then the iPhone. There is no way to stop the upgrades now. Fustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the hints; how can I get the beta firmware from support?
I'm using an app as baby monitor and the instability of this version is driving me absolutely mad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Longi
I have sent you a Pm.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
My unit is only about 2 months old. Is there no way to stop the auto updates???
Other then that is seems to work ok for the most part.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello camoit
No way to stop auto updating.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have started having the drop issues as well after about 30 days of the Orbi working perfect. All of my devices drop the wifi signal. Sometomes I can turn wifi off and back on at the device and sometimes I have to re-sync the satellite. I am getting very frustrated after spending this amount of money, My wifi signal wasn't as strong throughout the house before, but at least it was consistant.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Someone found a way by blocking the IP address that the Orbi checks for updates. It's on here somewhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM: could you also send me a PM re: beta firmware access? I'd like to stop the disconnections as well. Thanks much.
- Mark as New
- Bookmark
- Subscribe
- Permalink
same here. after the 1.10.1.2, my wifi is slow. and what is the reason netgear is not sharing the readme for this fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is a critical failure and Netgear is not addressing it. Please take a chance and look at your Backhaul signals and post your results! There's not a single example of one that does not look like an EKG.
- Mark as New
- Bookmark
- Subscribe
- Permalink
orbi just restarted itself, nothing shows in the log why. firmware is still the same. this is the 1st time this thing restarted itself for no reason. is this a known issue in 1.10.1.2?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you find that Ip address please post it. I can block it at the router level.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's in this thread: https://community.netgear.com/t5/Orbi/Firmware-update-URL/m-p/1179532#M1413
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cool. Thank you.
I have blocked IP address 216.151.177.114
Lets see if it gets updated again. I'll let you know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Darren,
Would you be able to send me a link to the beta firmware too? I have been having the same problems of intermittant connectivity mentioned in this thread since I updated to v1.10.12.
thanks,
neal
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have same problem, could you sent me the bata version fimware,
thanks for help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not being able to block firmware updates is a critical design flaw, and an absolute show stopper for any business deployment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have a half deacent router you can block it from updating. See post above.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
