- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How many satellites connected via Ethernet does an RBK50 support? Trying to connect a 3rd -no luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
How many satellites connected via Ethernet does an RBK50 support? Trying to connect a 3rd and it doesn't show up
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How many satellites connected via Ethernet does an RBK50 support? Trying to connect a 3rd -no lu
- Mark as New
- Bookmark
- Subscribe
- Permalink
According to Netgear, the maximum number of satellites depends on how many satellites are connected over the WiFi link:
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System As the article points out, Netgear recommends using Ethernet if the total number of satellites is greater than four because too many satellites consume the WiFi connection and reduce performance.
Adding satellite #3 does not come anywhere close to breaching this recommendation.
On the forum, the general advice is to add a new satellite in a specific procedure:
- Locate the new satellite near the router.
- Use a web browser to open the Orbi web interface.
- Select the bottom menu item, Add Orbi Satellite.
- Follow the procedure shown on the web interface.
- The satellite should appear on the Attached Devices screen in the top section, "Satellites" with a "Good" connection over WiFi.
- Once this has happened, connect a router LAN port to one of the satellite LAN ports with an Ethernet cable.
- Within a few minutes (nothing about Orbis is instant) the connection should change to "wired". Patience is a virtue. You may have to "Refresh" the Attached Devices screen several times for it to recognize the change.
- Once the status has changed to "Wired - Good", then it has been established that the satellite has been linked to the router and that the satellite is capable of using the wired connection.
- Then.... move the satellite to the desired location and connect it to the Ethernet cable.
If the satellite fails to appear on Attached Devices (within the usual "longer than I think it should take, damn it" time), that is an indication that something is wrong with the Ethernet link.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
