Orbi WiFi 7 RBE973
Reply
Multiple guest networks
Cmsommerville
Follower
Does Orbi support multiple guest networks? My wife and I work from home for different companies so we’d like to set up separate 5Ghz isolated networks for each of our work computers, a separate 5Ghz for personal use, and a 2.4Ghz AP for IOT devices that require it.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Guru
Re: Multiple guest networks
No.
Message 2 of 3
CrimpOn
Guru
Orbi may be the wrong product for you.
  • Only one Guest network.  (I understand the "business Orbi" supports two, but I do not have one.)
  • Normal interface does not support different SSID's for 2.4G and 5G primary (or Guest) networks.
    There is a "hack" that has enabled people to do this, but it is uncertain how long Netgear will permit the hack.
    Many of us maintain that there is a "work around" that allows IoT devices to connect without resorting to the hack.
However, I do not understand the need to have separate WiFi networks for two people who "work from home".
  • Surely if they connect to a corporate network it is through a VPN (or some encrypted mechanism)?
  • Do they have separate printers?
Anyway, my "two cents".  Take it for what it's worth.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2805 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
