× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Netgear RBK50-100NAR Orbi Home Mesh Wi-Fi System
redflame910
Hello I purchased the Netgear RBK50-100NAR Orbi Home Mesh Wi-Fi System in 2020. It worked great for a year. Suddenly in the past two weeks it goes down every 5 to 15 minutes. The signal from my modem is fine. There is no issue with the isp. I factory reset the Orbi and it worked great for about 8 hours then started doing the same thing. Has anyone had this happen? I don't mind spending the money to get tech assistance but if they can't fix it I would hate to waste the money on that. I feel like the product should have lasted longer than a year. Any ideas what could be causing this?
Message 1 of 5
Guru
Re: Netgear RBK50-100NAR Orbi Home Mesh Wi-Fi System
What firmware version are you on?
I've seen issues with the recent version.
Might try downgrading to a lower version and see if it helps.
Message 2 of 5
Guru
What exactly happens when this occurs?
Does the top ring LED turn ON on the RBR or RBS?
Message 3 of 5
redflame910
It is a Motorola and Model is E31U2V1
The network disappears from our network list in wifi settings. The modem still shows it is on with no disruption.
I have noticed some of the light spins blue on top of the Orbi.
For the most part the network disappears momentarily and then reappears. Thanks for responding.
Message 4 of 5
Guru
If the top ring turned ON it means something happended between the RBR and the modem where it caused the RBR to lose it's connection to the modem and short enough that the PINK light didn't come ON but the BLUE one did indicating the RBR got a connection again. Possible intermittent loss of signal on the ISP like or modem and modem would not exatctly tell you this.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Have them check for any signal loss or log entries ON the modem. This modem model is not the greatest and have seen others have similar problems with this model modem with Orbi systems. Might ask for something different or ask about using your own modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 769 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
