- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS20 Connected to RBR20 (AP Mode) stops transmitting client traffic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Shotgun house, Orbi RBR20 in the middle, 1 RBS20 about 25' away in both directions.
They have been working reasonably fine.
Now, 1 of the satellites shows 5G backhaul connection but, intermittently stops transmitting packets and the signal bounces up and down. Disconnect/reconnect ends up connecting to the RBR which is really out of range and traffic doesn't flow and better.
There are not diagnostic tools I can see to tell me if this is a satellite issue or a router issue.
I'm running the latest firmware which I installed a few days ago in case that was the problem.
Other notes, sometimes if I run Windows 10 Troubleshoot, it reports that the gateway couldn't be found so it resets the WiFi or wireless depending on the system and reports that the gateway was missing.
I only have this issue with one of the satellites so I'm disinclined to blame the client systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS20 Connected to RBR20 (AP Mode) stops transmitting client traffic
@vordesigns wrote:
.... sometimes if I run Windows 10 Troubleshoot, it reports that the gateway couldn't be found so it resets the WiFi or wireless depending on the system and reports that the gateway was missing.
Makes me ask you about the modem, if there is one, in front of your router.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Version: 2.7.3.2
Orbi: AP Mode (won't set time, can't check for updates)
Gateway SonicWall TZ series
RBR = Static IP
RBS = DHCP reservation static IPs
IPV6 disabled
Attached device map only reliablle for satellites, hosts on LAN sometimes not online but listed, not found on the network.
Had most of settings listed in config reference, unchecked fast switching and logging. Since it is an AP, uncheck other useless logging.
Will problably need to break out a wireless sniffer and see who is using what channel in the neighborhood..
Issue only happens with one of the satellites. Could be that they are too close to each other.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vordesigns wrote:
Version: 2.7.3.2
I should have spotted that in the subject.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
If you want to update the firmware, do it manually. Always a better bet.
The manual describes how to go about it. Or:
How to update firmware on your NETGEAR product | Answer | NETGEAR Support
And
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
But I don't understand this:
That label is a generic tag rather than a model number. (See question from @FURRYe38.) So it could be one of a bunch of things. Google says this is some sort of firewall thing. Not a "gateway" as many of us understand it.
I am probably missing something. With luck @FURRYe38 knows more about this atypical setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try swapping RBS locations with each other to see of the problem follows or not...
Try OFF the one RBS thats seem problematic and see if the problem continues or not with just one RBS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem seems to be the RBS, while it does connect to the RBR, it doesn't consistently ltransmit packets, removing the RBS allows a connection to the RBR, ping lag goes up but, it just tolerable.
When I rebooted the RBS and waited for it to come all the way up, it reports that it can't reach the RBR IP.
RBR reports device is connected with GOOD status.
I guess the hardware has just died and I'm SOL.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you re-load FW on to the RBS using the RBS web page using a wired PC then factory reset and sync to the RBR?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
