- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nothing will connect to RBS50 Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not been able to get anything to connect to the Orbi Satellite. It is connected to the router and has a good signal. The satellite is ~30-40 feet from the router. I have tried both Wired and wireless backbones. All of my wireless devices connect to the router on the second floor even though some of them are only a few feet from the satellite on the 1st floor. Both devices are on the latest firmware (v2.5.2.4) Daisy chaning is off and I have tried Fast Roaming both on and off. The house is ~5000sqf divded between 2 floors. I was actually getting better performance from my old Nighthawk and range entender. I have been through most of the forums but have not found any good solutions.
Any help would be appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nothing will connect to RBS50 Satellite
What happens if you turn down the power output of the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings to 50 or 25%. Then try to connect any wifi device to the RBS? Besure to disable the wifi radio on the wifi device for 5 seconds then turn it back ON?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@amadeous wrote:I have not been able to get anything to connect to the Orbi Satellite. It is connected to the router and has a good signal. The satellite is ~30-40 feet from the router. I have tried both Wired and wireless backbones. All of my wireless devices connect to the router on the second floor even though some of them are only a few feet from the satellite on the 1st floor. Both devices are on the latest firmware (v2.5.2.4) Daisy chaning is off and I have tried Fast Roaming both on and off. The house is ~5000sqf divded between 2 floors. I was actually getting better performance from my old Nighthawk and range entender. I have been through most of the forums but have not found any good solutions.
When this happens with wireless devices, sometimes the solution is to go to the devices that will not connect to the satellite and forget the wireless network.
Regarding wired devices, sometimes the app and/or GUI will report connected to router when in fact the device is connected to the satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have turned down the power on the 2.4 to 50%, it did not make a difference. Also a note if I power down the router my SSID completely dissapears to all devices. Shouldnt I still see the satellite? I have not performed a factory reset yet but I was having the same issue before I updated the firmware. I can try that next.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya you should still see the RBS SSID being broadcast. If not, then something isn't working on the RBS. Try a reset. Press the button in back for 15 seconds then release. Use the sync button in back after the top ring LED starts to pulsate WHITE, then press the sync button on the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would you happen to have anything that can connect to the Orbi using an ethernet cable? Would be useful to see if something plugged into the satellite gets an internet connection. Something like a laptop.
When I use a "WiFi Analyzer" app on my Android devices, it clearly shows the two SSID's (router and satellite). I have not powered the Orbi off for 4 months, so I am not interested in verifying that powering off the router will leave the satellite in operation. An ordinary WiFi extender or access point, sure. Something that is tied so intimately into the router.... hmmm.
p.s. The reason to disable Daisy Chain when there is only one satellite is because Daisy Chain creates another hidden 5G backhaul frequency to be used between the satellites. It's not a huge problem, but WiFi access points blast out "management frames" constantly and it's kind of pointless to do so without a reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I use a WiFi analyzer on my Android it only shows the Router SSID, the Satellite is not broadcasting. I included a screenshot of the satellite webpage showing that is thinks its functional.
- Mark as New
- Bookmark
- Subscribe
- Permalink
With your wifi analyzer are you near the RBS when your checking this? Remember the SSID is the same between the RBR and RBS and you should see two different signals, if your close to the RBS it would be the one thats the stronger signal on the same channel.
The status picture is of the RBS that is connected on 5Ghz, not 2.4Ghz and the NO Connection status means there isn't any devices connected at the RBS.
If you don't see any signal on your wifi analyzer while near the RBS, then something at the RBS isn't working. You might downgrade the RBS and RBR back to v16, factory reset both and setup from scratch.
You don't have to synce the RBS. Use your wifi anyalyzer near the RBS and check for the default SSID name to appear, ORBI###. If you don't see this near the RBS, I would presume the RBS has gone bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:With your wifi analyzer are you near the RBS when your checking this? Remember the SSID is the same between the RBR and RBS and you should see two different signals, if your close to the RBS it would be the one thats the stronger signal on the same channel.
So yeah, I downgraded the firmware on both devices did a factory reset on both devices, reconfigred everything and I still cannot get anything to connect to the Satellite. and When I shut down the router I get no SSID from the satellite. I tried calling Netnear and of course they will not even talk to me unless I Pay them $130 for support. What a joke.
- Mark as New
- Bookmark
- Subscribe
- Permalink
