× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
OBRI RBS50 ADD ON NOT SYNCING WITH EXISTING SYSTEM
TeeWrecks
Follower
I have the RBR50 system that works perfect. I bought an add on so I will have a total of 1 RBR50 and 2 RBS50's.
I plugged in a followed the snyc instructions and it wll not add. halo turn the purple color.
Is there a way to manually add the 3rd add on? Can I plug it in with the ethernet cable?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: OBRI RBS50 ADD ON NOT SYNCING WITH EXISTING SYSTEM
Hello Teewrecks
Yes you could try to connect the unit via ethernet and see if you can update the firmware and then if that works remove the cable and try to sync the unit again.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 607 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
