× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Orbi WiFi Speed
Diesel26
Orbi WiFi Speed
Hello,
I had new internet service installed today (300 Down / 20 Up).  Speed tests from the Orbi app and hardwired to the router show great speeds.  However, when I run any kind of speed test when connected to WiFi, the best download speed I can get is 13MB.  This is from broth iPhones and laptops.  Both Beamforming and Mu-MIMO are enabled.
Not sure if there is a problem with a setting or if this is related to a firmware issue.  Current firmware is 2.1.2.18.
Any help is appreciated.
Thanks,
Ben
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: Orbi WiFi Speed
Have you tried to remove all device from the wifi and then connect just 1 device and test the speed? it could be some older wifi device slowing the network down.
DarrenM
Message 2 of 5
linkwrt
Guide
Re: Orbi WiFi Speed
I have 1000mbps .
And i don't have any issue.
280mbps iphone se
590mbps macbook air.
Message 3 of 5
Diesel26
Re: Orbi WiFi Speed
I was able to resolve the problem on my own.
ADVANCED -> ADVANCED SETUP -> Enable WMM
Somehow multimedia settings enable more bandwidth?
Message 4 of 5
linkwrt
Guide
Re: Orbi WiFi Speed
WMM is enabled by default.
You should not disable WMM.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1661 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
