- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBR20 please help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR20 please help
can you give a picture of your setup and wiring?
you can probably just hand draw it on paper and take picture. Remember to put all the wires on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the problem is happening when the modem got switched, have you checked if Modem is loosing signals periodically?
where is the White cable going to?
do you have any MOCA based devices in the home?
Is your TiVO doing MOCA?
can you please continiously ping 192.168.1.1 and 192.168.0.1 and post here when the connection breaks?
Do you see disconnection on WIRED PC?
Please post the EVENT LOGS from the CODA device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure if any devices use moca, guessing not ? Nest cams, tablets are what I mainly use .
Wired PC stays connected I believe but nothing loads . 0mbps .
Will report back with logs once home thanks for replying
How do I know if my TiVo uses it ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe many TiVOs have MOCA in it. If you do have MOCA on it and it is enabled, do not connect connect those TIVOS via ethernet to Orbi. that will cause loop.
so action for you:
1. Check the event log for CODA. any Timeouts and disconnections?
2. Check the network log for the Orbi. Any WAN disconnections?
3. keep ORBI and CODA FAR APART. You have them right next to each other.
thanks,
VK
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the continued reply.. orbi unplugged my isp wifi and ethernet are fine.. soon as i plug orbi in didnt even last 10 minutes.
Moca is disabled on coda
dmz settings disabled
heres a log from coda: if its the right log ?
MTA Event Log
Index Date/Time Priority ID Text
1 2019/09/03 08:12:15 CRITICAL 3000000002 CM:50
2 2019/09/03 08:12:15 CRITICAL 3000000002 CM:50
3 2019/09/03 08:14:57 ERROR 3000000004 ;BAD_DHCP_ACK
4 2019/09/03 08:14:57 CRITICAL 3000000002 CM:50
5 2019/09/03 08:17:33 ERROR 3000000004 ;BAD_DHCP_ACK
6 2019/09/03 08:17:33 CRITICAL 3000000002 CM:50
7 2019/09/03 08:20:06 ERROR 3000000004 ;BAD_DHCP_ACK
8 2019/09/03 08:20:06 CRITICAL 3000000002 CM:50
9 2019/09/03 08:22:44 ERROR 3000000004 ;BAD_DHCP_ACK
10 2019/09/03 08:22:45 CRITICAL 3000000002 CM:50
11 2019/09/03 08:25:28 ERROR 3000000004 ;BAD_DHCP_ACK
12 2019/09/03 08:25:29 CRITICAL 3000000002 CM:50
13 2019/09/03 08:28:09 ERROR 3000000004 ;BAD_DHCP_ACK
14 2019/09/03 08:28:09 CRITICAL 3000000002 CM:50
15 2019/09/03 08:30:44 ERROR 3000000004 ;BAD_DHCP_ACK
16 2019/09/03 08:30:44 CRITICAL 3000000002 CM:50
17 2019/09/03 08:33:24 ERROR 3000000004 ;BAD_DHCP_ACK
18 2019/09/03 08:33:24 CRITICAL 3000000002 CM:50
19 2019/09/03 08:37:54 ERROR 3000000004 ;BAD_DHCP_ACK
20 2019/09/03 08:37:54 CRITICAL 3000000002 CM:50
21 2019/09/03 08:41:59 CRITICAL 3000000002 SNMP:50
22 2019/09/03 11:42:25 CRITICAL 3000000002 SNMP:50
23 2019/09/03 12:18:00 CRITICAL 3000000002 SNMP:50
24 2019/09/03 14:13:36 CRITICAL 3000000002 SNMP:50
25 2019/09/03 21:34:21 CRITICAL 3000000002 SNMP:50
26 2019/09/03 22:11:56 ERROR 3000000004 ;NO_PRIM_SF_USCHAN
27 2019/09/03 22:11:56 CRITICAL 3000000002 CM:50
28 2019/09/03 22:46:21 CRITICAL 3000000002 SNMP:50
29 2019/09/04 01:07:10 CRITICAL 3000000002 SNMP:50
30 2019/09/04 01:23:13 CRITICAL 3000000002 SNMP:50
31 2019/09/04 01:43:54 CRITICAL 3000000002 SNMP:50
32 2019/09/04 08:09:02 CRITICAL 3000000002 SNMP:50
33 2019/09/04 08:31:50 CRITICAL 3000000002 SNMP:50
34 2019/09/04 11:01:19 CRITICAL 3000000002 SNMP:50
35 2019/09/04 11:49:52 CRITICAL 3000000002 SNMP:50
36 2019/09/04 19:18:22 CRITICAL 3000000002 SNMP:50
37 2019/09/05 04:19:44 CRITICAL 3000000002 SNMP:50
38 2019/09/05 07:43:44 CRITICAL 3000000002 SNMP:50
39 2019/09/05 09:14:39 ERROR 3000000004 ;NO_PRIM_SF_USCHAN
40 2019/09/05 09:14:39 CRITICAL 3000000002 CM:50
41 2019/09/05 10:25:58 CRITICAL 3000000002 SNMP:50
42 2019/09/05 10:33:58 CRITICAL 3000000002 SNMP:50
43 2019/09/05 10:59:18 CRITICAL 3000000002 SNMP:50
44 2019/09/05 11:31:26 CRITICAL 3000000002 SNMP:50
45 2019/09/05 12:22:22 CRITICAL 3000000002 SNMP:50
46 2019/09/05 14:26:51 CRITICAL 3000000002 SNMP:50
47 2019/09/05 15:04:40 CRITICAL 3000000002 SNMP:50
48 2019/09/05 15:14:05 CRITICAL 3000000002 SNMP:50
49 2019/09/05 17:34:33 CRITICAL 3000000002 SNMP:50
50 2019/09/05 18:13:27 CRITICAL 3000000002 SNMP:50
51 2019/09/05 22:11:03 CRITICAL 3000000002
SNMP:50
heres another log:
DOCSIS Logs
The DOCSIS event logs is shown here
No. Time Type Priority Event
1 Thu Sep 5 21:46:20 2019 74010100 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
2 Thu Sep 5 21:46:35 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
3 Thu Sep 5 21:46:36 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
4 Thu Sep 5 21:50:47 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
5 Thu Sep 5 21:50:50 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
6 Thu Sep 5 22:04:49 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
7 Thu Sep 5 22:05:02 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
8 Thu Sep 5 22:05:02 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
9 Thu Sep 5 22:05:11 2019 74010100 6 CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
10 Thu Sep 5 22:05:48 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
11 Thu Sep 5 22:05:53 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
12 Thu Sep 5 22:06:10 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
13 Thu Sep 5 22:06:21 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
14 Thu Sep 5 22:07:53 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
15 Thu Sep 5 22:07:59 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
16 Thu Sep 5 22:11:04 2019 90000000 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
17 Thu Sep 5 22:11:05 2019 73040100 6 TLV-11 - unrecognized OID;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
18 Thu Sep 5 22:11:05 2019 68001102 3 Config File Rejected due to Invalid or Unexpected TLV 11;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
19 Thu Sep 5 22:11:08 2019 73050400 5 REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
20 Thu Sep 5 22:11:08 2019 82001200 5 RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
Clear
not sure but i rebooted just before 10 pm and then by 10 06 or before it was offline again ( or should i say very weak signal aka 0 mbps ) seems the orbi doesnt last long now before its purple on top
i pinged each one once.
Microsoft Windows [Version 10.0.18362.295]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\Users\Cody>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data
Reply from 192.168.0.1: bytes=32 time=1ms TTL=64
Ping statistics for 192.168.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 1ms, Average = 1ms
C:\Users\Cody>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\Cody>
logs from orbi
[admin login] from source 192.168.0.92, Thursday, September 05, 2019 21:26:32
[admin login failure] from source 192.168.0.92, Thursday, September 05, 2019 21:23:40
[Time synchronized with NTP server] Thursday, September 05, 2019 21:22:52
[admin login] from source 192.168.0.92, Thursday, September 05, 2019 21:22:00
[Internet connected] IP address: 192.168.0.8, Thursday, September 05, 2019 21:21:45
[WLAN access rejected: incorrect security] from MAC address 8a:d2:94:ae:fe:83, Thursday, September 05, 2019 21:21:36
[Initialized, firmware version: V2.3.5.26] Thursday, September 05, 2019 21:21:20
other info:
IP Address
192.168.0.8
Subnet Mask
255.255.255.0
Default Gateway
192.168.0.1
DHCP Server
192.168.0.1
DNS Server
192.168.0.1
Lease Obtained
7 Days, 0 Hours, 0 Minutes
Lease Expires
6 Days, 23 Hours, 52 Minutes
not sure if im doing exactly whats asked here but i hope so!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
had to reboot my coda and plug the ethernet in coda to copy and paste all this stuff . from coda.
1 Thu Sep 5 22:05:48 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
2 Thu Sep 5 22:05:53 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
3 Thu Sep 5 22:06:10 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
4 Thu Sep 5 22:06:21 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
5 Thu Sep 5 22:07:53 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
6 Thu Sep 5 22:07:59 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
7 Thu Sep 5 22:11:04 2019 90000000 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
8 Thu Sep 5 22:11:05 2019 73040100 6 TLV-11 - unrecognized OID;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
9 Thu Sep 5 22:11:05 2019 68001102 3 Config File Rejected due to Invalid or Unexpected TLV 11;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
10 Thu Sep 5 22:11:08 2019 73050400 5 REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
11 Thu Sep 5 22:11:08 2019 82001200 5 RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
12 Thu Sep 5 22:23:20 2019 67050300 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
13 Thu Sep 5 22:29:36 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
14 Thu Sep 5 22:29:36 2019 74010100 6 CM-STATUS message sent. Event Type Code: 21; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
15 Thu Sep 5 22:29:38 2019 82000200 3 No Ranging Response received - T3 time-out;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
16 Thu Sep 5 22:29:42 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
17 Thu Sep 5 22:29:43 2019 82000200 3 No Ranging Response received - T3 time-out;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
18 Thu Sep 5 22:29:51 2019 74010100 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
19 Thu Sep 5 22:31:54 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
20 Thu Sep 5 22:32:14 2019 74010100 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
Clear
- Mark as New
- Bookmark
- Subscribe
- Permalink
Logs
Current Time: Thursday, Sep 05, 2019 21:59:52
[admin login] from source 192.168.1.12, Thursday, September 05, 2019 21:59:26
[DHCP IP: 192.168.1.7] to MAC address 18:b4:30:db:8e:2d, Thursday, September 05, 2019 21:59:08
[DHCP IP: 192.168.1.10] to MAC address e0:9d:31:72:a8:24, Thursday, September 05, 2019 21:58:05
[DHCP IP: 192.168.1.12] to MAC address a0:cc:2b:c5:2e:68, Thursday, September 05, 2019 21:57:46
[DHCP IP: 192.168.1.3] to MAC address 64:16:66:7b:2e:f2, Thursday, September 05, 2019 21:57:28
[DHCP IP: 192.168.1.11] to MAC address 78:d2:94:ae:fe:88, Thursday, September 05, 2019 21:57:09
[DHCP IP: 192.168.1.10] to MAC address e0:9d:31:72:a8:24, Thursday, September 05, 2019 21:56:57
[DHCP IP: 192.168.1.5] to MAC address 78:d2:94:ae:fe:83, Thursday, September 05, 2019 21:56:56
[DHCP IP: 192.168.1.10] to MAC address e0:9d:31:72:a8:24, Thursday, September 05, 2019 21:56:36
[DHCP IP: 192.168.1.9] to MAC address 64:16:66:7a:f0:e0, Thursday, September 05, 2019 21:56:36
[DHCP IP: 192.168.1.8] to MAC address 00:07:a6:0d:d1:45, Thursday, September 05, 2019 21:56:23
[DHCP IP: 192.168.1.7] to MAC address 18:b4:30:db:8e:2d, Thursday, September 05, 2019 21:56:22
[DHCP IP: 192.168.1.5] to MAC address 78:d2:94:ae:fe:83, Thursday, September 05, 2019 21:56:16
[DHCP IP: 192.168.1.6] to MAC address 30:8c:fb:84:0c:79, Thursday, September 05, 2019 21:56:14
[DHCP IP: 192.168.1.4] to MAC address 18:b4:30:66:d7:ad, Thursday, September 05, 2019 21:56:13
[DHCP IP: 192.168.1.3] to MAC address 64:16:66:7b:2e:f2, Thursday, September 05, 2019 21:56:10
[DHCP IP: 192.168.1.2] to MAC address 00:07:a6:0d:cc:d6, Thursday, September 05, 2019 21:55:57
[Time synchronized with NTP server] Thursday, September 05, 2019 21:55:54
[Internet connected] IP address: 192.168.0.9, Thursday, September 05, 2019 21:55:34
[Internet disconnected] Thursday, September 05, 2019 21:54:56
[admin login] from source 192.168.0.9, Thursday, September 05, 2019 21:52:38
[Initialized, firmware version: V2.3.5.26] Thursday, September 05, 2019 21:48:14
Attempted access to allowed sites
Attempted access to blocked sites and services
Connections to the Web-based interface of this Router
Router operation (startup, get time etc)
Known DoS attacks and Port Scans
Port Forwarding / Port Triggering
Wireless access
VPN Service
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does this make any sense ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the model# of the new modem?
Is the RBR in AP mode still? If so, you should be getting internet thru the Orbi RBR and it's wifi.
They really should have used a separate SSID name for your TV services WiFi. This may confuse you and your wireless devices and your wireless devices will connect to the ISP modems wifi instead of the Orbis wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't believe they share the same public wifi with the tv but a different wifi or something in the modem..
I'm really not sure, I will report back
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi router front of house basement.
Satellite 1 back of house main level.
Everything been fine 300 ish Mbps sitting outside .
Satallite 2 plugged into garage, before even with 120 Mbps I'd get 30-40. Id expect atleast 100 as it's not far from satellite 1. Right now I'm getting 10-25 Mbps.
Satellite 2 is poor
Could you help me resolve this 😝.
This is a pic of satellite 2.. right on other side of wall is satellite 1 .. if I'm close to wall I get 300+ Mbps.. inside garage no good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I saw in one of the screenshts from the Hitron router that it has a DMZ setting, have you tried that?
Please set up the IP address of the Orbi (192.168.0.92 or another address if it has changed) as the DMZ destination in the Hitron router.
Reserve a fixed IP address for Orbi in the Hitron Router so that it does not keep changing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what you have got here is "Daisy chain" setup in the Orbi. It will automatically choose this setting as your Sat-2 is wirelessly-far from Router. May be there many obstructions here.
It will display poor if the Backhaul rate is poor.
you could try changing the positions of Sat 1 to see if it be bit more closer to sat2.
if you draw a top down view of your house floor plan, someone can probably comment more.
Is your disconnection problem solved by just removing CODA off your home?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reboot everything , did one satellite at a time because I noticed sat 2 would try to take from the router instead of sat 1, and all of a sudden everything is GOOD.
My setup now goes as followed .
1050 sq ft bungalow ( downstairs + main level ) I think my house is like 50 ft or something long ?
Router and modem basement front of house closest to wall
Sat 1 main level closest to back wall of house
From back of house to garage door 20 ft ish+15 ft to sat 2
Sat 2 is in my garage farthest away possible from sat 1 .
Everything seems to be working a ok.
My guess is it was the hitron coda 4589 modem causing the connection issues .
The only weird thing is if I goto the back of my house to the middle while on main floor I get 40 Mbps unless i turn wifi on and off for it to rrconnt to the closest orbi or something.
Now getting speeds around 150 in garage ..is this normal? I get 600 ish beside router, I have 1gb I understand wifi is less but is the Singal supposed to carry that 600 or lose a bit ? It seems sat 1 gives almost full whereas sat 2 is 150 or so.
For now everything is ok, I just want to say a big thank you to the 3 guys on this post assisting with everything they can .
- Mark as New
- Bookmark
- Subscribe
- Permalink
At this point I'm quite happy. Nothing is disconnecting constantly.. both orbi status are good.
