× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi Mesh RBR10
dferraro
Follower
Orbi Mesh RBR10
How do I determine if my network is set to 5 GHZ or 2.4 GHZ and how do I change it if needed?
Message 1 of 3
CrimpOn
Guru
Re: Orbi Mesh RBR10
All Orbi WiFi routers broadcast on both 2.4G and 5G WiFi. This cannot be 'changed'.
Is there a specific reason for the question?
Message 2 of 3
KevinLiT
NETGEAR Moderator
Re: Orbi Mesh RBR10
Hello @dferraro ,
I understand you that would like to know which network band you are using on your network and if there is a way to manually pick a network band. For the RBR10 there is no way to choose the desired network band. This is applied automatically depending on the most optimal network band for the device.
To figure out which network band you are using please follow the steps below.
On a Windows PC, simply do the following:
Select the Wi-Fi icon on the taskbar
Then select properties
Next, scroll down to "Network Band".
Finally, You will see either 5GHz or 2.4GHz
Let me know if you have any additional questions!!!
Best,
Kevin
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 818 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
