- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK50 + Starlink Invalid Gateway IP Address
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is my config ...
Internet Port
IP Address: 100.65.16.0
Connection: DHCP
IP Subnet Mask: 255.192.0.0
Static Route
Destination IP Address: 192.168.100.0
IP Subnet Mask: 255.255.255.0
Gateway IP Address: 100.x.y.0
Metric: 2
I can put anything but 0 and 255 into that last digit on the gateway IP and it will accept it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK50 + Starlink Invalid Gateway IP Address
@Dishy wrote:
Now, for the first time, my Dishy assigned my router an IP ending in .0. Orbi is telling me that it's an invalid gateway IP address. Any ideas?
Wow, I didn't realize that legal IP addresses can end in 0: https://stackoverflow.com/questions/14915188/ip-address-ending-with-zero. Seems like the Orbi needs to be updated to support such IP addresses.
In the meantime, can you force your Dishy to assigned another IP address to your router (and hope you get one that the Orbi will accept)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
(The best part of this community forum is hearing about unusual situations.)
Could you please provide a little more background about this use of 'static routes', in particular where the static route is being defined. (on Starlink or on Orbi).
The way I understand it, static routes on the Orbi provide a method for devices on the local LAN to find IP addresses that cannot be reached through the usual gateway (the Orbi LAN IP address). With the typical Orbi subnet mask of 255.255.255.0, when a device wants to communicate with any other device that has the same /24 prefix, it uses ARP to find the MAC address of the device and sends packets directly to it. When the target device has an IP that is not in the same subnet, it sends packets to the gateway and says, "You figure it out."
Sometimes the Orbi WAN interface has no idea where to find that IP. In that case, a static route on the Orbi says, "instead of using the Orbi gateway, send packets destined for that IP address to this other gateway on the Orbi LAN. It doesn't matter what the target IP address ends with, but the 'gateway' has to be an IP on the Orbi subnet.
The way I picture this situation:
Starlink has given the Orbi WAN interface 100.65.16.0 with a subnet mask of 255.192.0.0 (one damn big subnet of 4,194,302 addresses)
Orbi has created a typical subnet of 192.168.1.0 with subnet mask 255.255.255.0 (256 addresses).
Some device on the Orbi LAN needs to connect to 100.x.y.0 and using the regular Orbi gateway cannot find it.
I obviously am misunderstanding something.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suspect that the Orbi may not allow a .0 gateway but was hoping that maybe I was attempting something improper with the subnet mask, about in which I know very little. But I guess a .0 Subnet mask should allow all addresses 0 to 255. It's just strange that Netgear wouldn't support the standard 20 years after it's implemented, so I assumed something else must be wrong.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Dishy wrote:
So I need something to tell the Orbi to send the traffic for 192.168.100.0 over the WAN port. It's always been a bit of a pain because that WAN IP for Orbi changes every so often (days or weeks) and I need to update the static route when it does
A static route on the Orbi must point to a LAN port on the Orbi, not the WAN port. As it is, the Orbi already recognizes that 192.168.100.0 in not on the LAN, and the way to reach that IP address is to use the WAN port.
See page 76 on the RBR50 user manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dishy,
When assigning a static IP address to a device you have to make sure that the desired IP address is on the same network as all the other devices on the network. The .0 in the fourth octet is a network IP address is not a client IP address. That is why you had configuration issues when trying to assign that IP address to a device in your network.
Best,
Kevin
community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Destination IP Address: 192.168.0.1
Gateway IP Address: 100.x.y.z (removed for privacy)
Metric: 2
What I don't understand is that multiple people are telling me that the Gateway IP must be on the 192.168 network and that's not what's working for me. If I deactivate this static route, then the Starlink app on my phone won't work. With it active, the app works and can communicate with the dish. I can't explain WHY this works, only THAT it works. 🙂 I can also say that every other Starlink user who wants to do this is using these same settings as above and I've now confirmed with 2 different users that their routers of other brands will accept a 100.x.y.0 address as the Gateway IP.
There are some details on this here which go beyond my knowledge level: https://www.reddit.com/r/Starlink/comments/jxkz1q/anyone_know_how_to_get_the_starlink_app_to_work/ and here https://www.reddit.com/r/Starlink/comments/jqhoqz/starlink_app_works_fine_behind_own_router/gby79x1?....
As for me, I'll leave it to you more knowledgeable people to try and understand the details and I'll just hope that I don't get another .0 address from Dishy. 🙂
