Orbi WiFi 7 RBE973
Reply
Orbi Router
shanelester
Follower
Orbi Router
I have a new Arris modem, and i've tried for hours to connect to Orbi to send out my wireless signal.    Arris rep told me to call ORBI for some mac spoofing (which I have no idea what that is).
Does any have a suggestion on what to do so the connection between my router and my modem sends out our wireless signal?
Thanks for any suggestions.   I've reset to default many times.    My Orbi app on my phone shows connected by NO INTERNET.
Thank you
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: Orbi Router
It would help to know the model number of the Arris modem and the Internet Service Provider.
"Mac Spoofing" means telling the Orbi to pretend to have a different ethernet adapter Media Access Control (MAC) address.  This is only necessary when the ISP has set their modem to connect with only one specific ethernet adapter and it is easier for the subscriber to make the new router pretend to be the old one than to contact the ISP.  I doubt very much that this is the case here.
The Orbi will generate a WiFi signal even when it is not connected to the internet.  The Orbi app says "connected". Is it safe to assume that you want to configure the Orbi using the smartphone app, rather than a web browser connected to the Orbi web interface?
The issue seems to be the internet connection.
Message 2 of 3
Guru
Re: Orbi Router
If your modem already has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thank you
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 401 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
