- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did option 3. It is now working but the signal is not much better then waht it was pre orbi. Do you know if there is a way to test where I will ge tthe strongest signal? I saw the pics but those dont do much.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
@Poomero wrote:
I just bought an Orbi rbk50 and I am confused. When I set the orbi up I had to log in and then my internet wasn't working. I then logged into my wifi router and it worked. Do I stay logged into the router or o I need to log in to orbi?
The Orbi does not require anyone to be logged in to function. Perhaps there is some confusion between the three types of Orbi logins:
- The Orbi WiFi SSID/password.
Needed for devices to connect via WiFi. - The Orbi administrative password (user name is always "admin"), which gains access to the Orbi web management interface.
- The Netgear account login, which is used to access the Orbi "app".
So, the initial login was which one?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
Have you powered OFF the ISP Modem and RBR for 1 minute then back on with the modem then the RBR? You might do this then reset the RBR to factory defaults and walk thru the set wizard with a wire connected PC and web browser pointed at 192.168.1.1 or orbilogin.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
The router is a Netgear c3700. I have reset it and done the set up again. I dont know how to do the wired set up though. I will have to emss with this later because I am working now and need internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
The C series modem already has a built in router and WiFi.
You can bridge or disable NAT/router and wifi on the C series modem then use the RBR in router mode. Review the user manual for the modem regarding this.
Do this when you get a moment.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
You are speaking a different language. I will take a look and see what I can come up with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
![](/skins/images/8E989D332A0B1F9B5E34CB445B6B1D9D/responsive_peak/images/icon_anonymous_message.png)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
@Poomero wrote:I did option 3. It is now working but the signal is not much better then waht it was pre orbi. Do you know if there is a way to test where I will ge tthe strongest signal? I saw the pics but those dont do much.
what firmware are you using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
WiFi Sweet Spots on a phone or pad can help.
Try and find a wifi analyzer on a pad if you have one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
I have no idea. How do I see that? What is reccommended?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
You can find the version on the RBRs web page at orbilogin.com or 192.168.1.1 in a web browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
Try some of the suggestions.
Please give feedback to the questions presented if you can.
A factory reset and setup from scratch with a wired PC and web browser connected to the RBR maybe needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
Why would I need to try anything more? I have it all working now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection
Ok, if so, make a back up configuration to file for safe keeping.
Mark your thread as solved.
Now enjoy.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
