Orbi WiFi 7 RBE973
Reply
Orbi excessive pinging
Guru
Re: Orbi excessive pinging
Message 26 of 30
kwiebe
OK great - does the ping behavior carry forward with the newer firmware?
Message 27 of 30
Guru
Heres my ping with my mac book wirelessly connected pinging the RBR50:
PING 192.168.0.1 (192.168.0.1): 56 data bytes
64 bytes from 192.168.0.1: icmp_seq=0 ttl=64 time=21.581 ms
64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=5.296 ms
64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=7.785 ms
64 bytes from 192.168.0.1: icmp_seq=3 ttl=64 time=13.785 ms
64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=16.978 ms
64 bytes from 192.168.0.1: icmp_seq=5 ttl=64 time=12.250 ms
64 bytes from 192.168.0.1: icmp_seq=6 ttl=64 time=10.974 ms
64 bytes from 192.168.0.1: icmp_seq=7 ttl=64 time=8.575 ms
64 bytes from 192.168.0.1: icmp_seq=8 ttl=64 time=12.546 ms
64 bytes from 192.168.0.1: icmp_seq=9 ttl=64 time=24.586 ms
64 bytes from 192.168.0.1: icmp_seq=10 ttl=64 time=7.343 ms
64 bytes from 192.168.0.1: icmp_seq=11 ttl=64 time=5.241 ms
64 bytes from 192.168.0.1: icmp_seq=12 ttl=64 time=4.750 ms
64 bytes from 192.168.0.1: icmp_seq=13 ttl=64 time=10.755 ms
64 bytes from 192.168.0.1: icmp_seq=14 ttl=64 time=13.280 ms
64 bytes from 192.168.0.1: icmp_seq=15 ttl=64 time=12.145 ms
64 bytes from 192.168.0.1: icmp_seq=16 ttl=64 time=12.212 ms
64 bytes from 192.168.0.1: icmp_seq=17 ttl=64 time=5.385 ms
64 bytes from 192.168.0.1: icmp_seq=18 ttl=64 time=11.898 ms
64 bytes from 192.168.0.1: icmp_seq=19 ttl=64 time=12.723 ms
64 bytes from 192.168.0.1: icmp_seq=20 ttl=64 time=13.254 ms
64 bytes from 192.168.0.1: icmp_seq=21 ttl=64 time=4.815 ms
64 bytes from 192.168.0.1: icmp_seq=22 ttl=64 time=6.125 ms
64 bytes from 192.168.0.1: icmp_seq=23 ttl=64 time=14.790 ms
64 bytes from 192.168.0.1: icmp_seq=24 ttl=64 time=12.195 ms
64 bytes from 192.168.0.1: icmp_seq=25 ttl=64 time=12.695 ms
64 bytes from 192.168.0.1: icmp_seq=26 ttl=64 time=18.840 ms
64 bytes from 192.168.0.1: icmp_seq=27 ttl=64 time=5.331 ms
64 bytes from 192.168.0.1: icmp_seq=28 ttl=64 time=15.378 ms
This is with everthing online.
Message 28 of 30
kwiebe
Thanks but the ping issue described in this thread is the fact that Orbi satellites for some reason incessantly ping their default gateway. The issue has nothing to do with clients connected to the network, such as your Mac. Do your satellites exhibit that behavior?
Message 29 of 30
Guru
Not that I can tell however I don't have a firewall appliance between the ISP modem and RBR/RBS so I can't be fore sure.
Regardless, yours maybe already exhibiting this issue and would be worth trying to update to see, or make contact with NG support. If something this happening, theres not much we can do about it here in the forums and you would need to file a support ticket and see if NG can correct it if it's causing problems for you. My 50 series system has been working fine for me on v16. I may update to v32 something later this week.
Message 30 of 30
Top Contributors
Discussion stats
  • 29 replies
  • 3119 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
