- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6700 with RBK22
- Mark as New
- Bookmark
- Subscribe
- Permalink
R6700 with RBK22
I need to expand the wifi coverage in my home. 2400 sf, 2 story structure. I want to be able to get wifi signal outside.
I currently have Verizon Fios with a Quantum Gateway router with wifi on located in the basement and a Nighthawk R6700 set up as a second wifi router on the first floor. Both are set up with the same SSID.
I want to set up RBK 22 Orbi sytem for expanded mesh network coverage. I would like to keep NH 6700 in the mix. If so, how do I configure this?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6700 with RBK22
IF your ISP modem has a built in router already, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
I would try option #2 with the RBK system and not use the R series router. The RBK system should be enough.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
You can use the R series router in AP mode behind the RBK system though it will need to have a separate SSID name and use different channels far apart from what the RBK uses.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you FURRYe38. I will give these a try. My home is 2400 SF. 30 ft between router and satellite should not be an issue. Appreciate your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
