Orbi WiFi 7 RBE973
Reply
RBK50 AC3000 Ethernet and wireless
snoopy77
Can you have one Satelite connected via Ethernet back to the Router and the other Satelites working on wireless ? , if so do you need to change any settings on the devices or will it just work?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Guru
Re: RBK50 AC3000 Ethernet and wireless
Yes you can do that and no you don't need to change any settings. I haven't needed to change any settings and I routinely do this.
Message 2 of 4
snoopy77
I'll assume that the Satelite will then talk back to the other Satelite or the Router depending on which one is closest?
Message 3 of 4
Guru
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Once RBS are wirelessly connected, just connect the ethernet cable in between the RBR and RBS.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 448 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
