Orbi WiFi 7 RBE973
Reply
RBR50/RBS50 - can I connect a Netgear AC1750 Mesh Extender?
NikS55
I have a working Orbi network with RBR50 and RBS50 satellite in my home.  My son has just moved back home and brought his Netgear AC1750 Mesh Extender with him.  We have tried to connect this with the Orbi network without success so far.  Surely these two Netgear products are compatible?  Any advise would be appreciated.
Model: A6200|802.11ac Dual Band WiFi USB Adapter
Message 1 of 6
Accepted Solutions
Guru
Re: RBR50/RBS50 - can I connect a Netgear AC1750 Mesh Extender?
Most extenders are not compatible. Other users have contacted NG support abou the EX3700 and was reported to get FW from NG to make that work with the Orbi system. I got FW for my EX7700 that works with mine. Contact NG support to see if they might have something.
Message 2 of 6
All Replies
Guru
Message 2 of 6
NikS55
Excellent!   I downloaded the latest firmware for the Ex6250 and it connected to my Orbi network successfully. Thanks for your response.
Model: EX6250|AC1750-WIFI MESH EXTENDER
Message 3 of 6
Guru
Good to hear and glad to know that it works.
Enjoy. Smiley Wink
Message 4 of 6
Guru
My EX7500 works as well:
  • Hardware Version: EX7500
  • Firmware Version: V1.0.0.64_1.0.74
    Connection to Existing Network (2.4GHz)
    • Signal Strength: 400 Mbps
    • Name (SSID):
    • Connection Status: Connected
      Connection to Existing Network (5GHz)
      • Signal Strength: 867 Mbps
      • Name (SSID):
        Extender WiFi Status (2.4GHz)
        • Name (SSID):
        • Region: North America
        • Channel: Auto ( 11(P)+7(S) )
        • Wireless mode: Up to 400 Mbps
        • Wireless AP: On
        • Broadcast Name: On
        • Wi-Fi Protected Setup:  Configured
          Extender WiFi Status (5GHz)
          • Name (SSID):
          • Channel: 149 + 153 + 157(P) + 161
          • Wireless mode: Up to 867 Mbps
          • Wireless AP: On
Message 5 of 6
Guru
Here's my EX7700:
  • Hardware Version: EX7700
  • Firmware Version: V1.0.0.206
    • Signal Strength: 400Mbps
    • Name (SSID):
    • Channel: 11
      • Signal Strength: 780Mbps
      • Name (SSID):
      • Channel: 48
        • Name (SSID):
        • Channel: 7(s) + 11(p)
        • Region: United States
        • Wireless AP: ON
        • Broadcast Name: ON
        • WPS: Configured
        • Security Type: WPA2-PSK[AES]
          • Name (SSID):
          • Channel: 149 + 153 + 157(p) + 161
          • Wireless mode: Up to 866.7 Mbps
          • Wireless AP: ON
          • WPS: Configured
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1944 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
