× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
RBR50 firmware update
JitM
I have got following email from Netgear for my RBR50.
We've Enhanced Your Product's Security.
Please Update to the Latest Firmware.
But when I check for updates from app it shows no new firmware is available.
I am on V2.5.2.4 not sure if I am missing any important updates in UK.
Regards
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 11
Accepted Solutions
Guru
Re: RBR50 firmware update
Be sure to make a back up configuration to file for safe keeping on the RBR. Helps save time if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
Message 11 of 11
All Replies
vajim
Master
Regards
1.  forget the app.  IF you must check, try via PC login
2.  IF it were related to an actual security vulnerability then NG would auto push it.  No action required.
3.  IF you want to upgrade the choice is yours with caution as always since these firmware release are known to have bugs
Message 2 of 11
Guru
Next version after v4 is v40:
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-Version-2-6-1-40/m-p/1997895/highlight/tr...
It's one that may have not been put up on the auto update servers so it may not appear as a notification on the RBRs web page.
v104 is also available. it's on the auto update server however you'd have to manually update to v40  I believe first to see v104. Or you can manually download and manually update to v104 directly with a wired PC and web browser:
https://community.netgear.com/t5/Orbi/New-Orbi-RBR50-Router-Firmware-Version-V2-7-2-104-Released/m-p...
Or you can keep what you have loaded as well. Up to you though.
Regards
Message 3 of 11
vajim
Master
Proceed with caution and ask yourself why this may not appear as a notification on the RBRs web page and WHY users in here keep posting stuff like this???
Message 4 of 11
JitM
Thanks to All who responded this thread.
I have got new iphone app update of Netgear and after that I can see 2.7.2.104 version available to update. I have added the screenshot. I will try it over the weekend.
Thanks
Message 5 of 11
jwh49
After installing the latest firmware I can no longer login to the router. It will not accept my passords or the answers to my security questions.
Message 6 of 11
alokeprasad
Mentor
Strongly advise to use the web interface of the RBR50 instead of the smartphone app if you proceed.
How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Message 7 of 11
jwh49
The firmware update was successful since my WiFi network is up and running after applying it using the updated Orbi iPhone app. I just cannot login using the correct password, serial number and secuity question answers.
Message 8 of 11
Guru
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Message 9 of 11
jwh49
Thanks, that worked. Both the RBK50 and RBS50 now have current firmware but the RBW30 will NOT install, after downloading, even using Manual upload.
Message 10 of 11
Guru
Enjoy. Smiley Wink
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2060 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi 770 Series
