Orbi WiFi 7 RBE973
Reply
Rbr20connect to bell gighub
outdoor
iM trying to get my orbi to connect to bell gigahub so i can use my own router
Followed some instructions but not working
On bell turn ofF unpl dnla  turn off wifi  turn on dmz
Connect orbi to bell through silver port.  not sure what to do on orbi because the bell does not see it and Orbi is not connecting to internet
Ip of bell is 192.168.2.1
Set orbi to 192.168.2.2
What am i doing wrong?
Message 1 of 5
Guru
Re: Rbr20connect to bell gighub
Set orbi to 192.168.1.1
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Message 2 of 5
outdoor
Regarding # 2
I think that is what i'm trying to do?
on the Bell router/modem i disabled all wifi radios.  I turned on DMZ (not sure what exposed host is)  I added the MAC address of the orbi router to the active device. Turned off DNLP and UPnP.  Connect orbi to Bell
Is that all i do on Bell router/modem?  what should show in DHCP of Bell router/modem?
I'm not clear what to do on Orbi side?  Do i change the router IP address to 192.168.2.2 (since Bell is 192.168.2.1)  do i need to change IP from dynamic from ISP or something else?  or is that it?  then what reboot both?  I've tried all this and not working
Message 3 of 5
Guru
Set orbi side to 192.168.1.1
Should be nothing else do to on the modem or Orbi side/
Might power OFF the modem and RBR for 30 seconds then back ON with the modem first then RBR. Top ring should turn OFF after 5 minutes or so, indicating the RBR has a connection to the modem.
Message 4 of 5
outdoor
Still not working
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 788 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
