- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbs50v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
My satellite was not connecting with any devices and then intermittent it would. Devices connected to it had intermittent notices that no internet available while all other devices connected to router and internet. After 4 times with support a new satellite was sent out and I got it up and running, green lights on router and satellite, back haul good! My phone connected to the satellite for a short time then went to router. Now no devices connect to the satellite.
How do I get the devices to connect again to the satellite? Before not all devices connected to the satellite but some would depending on proximity to satellite.
help!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
20' is too close between the RBR and RBS. 30 feet is a starting point the going farther.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbs50v2
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
It's up to the wifi device to pick and choose which signal to connect too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbs50v2
The distance between them is about maybe 20'. The satellite is in the basement and the router is on the 2nd floor. So I have three stories actually. Do you think the devices will come around on their own and connect when my wife is in basement office. The printer is across from the satellite in the basement and it usually always connects to the satellite. Some of the devices like the 2.4ghz and go to the satellite. I checked again everything is connected to the router. I have 11 devices that connect. I will try your suggestion slowing speed down. Thank you ! I'll let you know what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
