- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Scheduled Reboot - crond and cronjob
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
There is no option for a scheduled restart of the router through the Web Interface, although each router should have this option by default as a weekly restart of any router is almost required.
I have enabled telnet, but how do I enable the crond daemon in busybox? I can telnet into the router, and all the required commands are there such as reboot, crond, so there must be an option for me to add an entry for a cronjob to reboot at a specified time of each week.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Scheduled Reboot - crond and cronjob
Found it, it works fine with the unix normal cronjobs.
Example below (reboots at 1am everyday):
01:00 * * * /sbin/reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
An interesting development. Thanks for sharing. Although, I take exception to the theory that "a weekly restart of any router is almost required". My Orbi has remained on-line for over 100 days several times without problem. It would have gone longer, but I decided to mess around with firmware updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If a restart or reboot is needed frequenty, this means there is a problem with the Orbi system or the envrionment or configuration that the system is currently in. It would need to be investigated to see where the real problem is. Scheduled reboots are just covering up the real cause of the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mainly use the Orbi(RBR50) as an AP, with 3x Satellite (2x RBS50, 1xRBV40), and my main router is an Asus RT-AC88U. Simply because the Asus has a better router management interface.
I just realised although I can schedule the reboot over a cronjob, the telnet and cronjobs are not static! I still need to enable telnet after the reboot, and need to re add the cronjob....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ethernet switch in the configuration? or directly wired to the host router?
I presume all wifi is turned off on the main host router.
What other wifi devices do you have running?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
@imaz wrote:
Mine seems to perform slow over wifi devices, drops out of simply doesn’t want to route traffic. It’s even worst when my kids play their pc games and the satellite takes higher priorities over clients as the pc is connected over Ethernet on one of the satellite.
