× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Using RBR20 ORBI as a satellite
77PALE77
Apprentice
Hi everyone,
I have an Orbi RBR20 router connected with a Orbi RBS20 satellite. I wonder if I can use another RBR20 router as a satellite instead of another RBS20.
Thanks a lot
Pale77
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: Using RBR20 ORBI as a satellite
Sorry, No.  Even though they often appear to be the exact same hardware, the firmware for Orbi router and satellite are different.  A router can only be a "router", never a satellite.
What you CAN do is attach the router to your Orbi as an "Access Point" (AP), which means:
  1. It performs no router functions
  2. It is not part of the Orbi "system".  i.e. it doesn't coordinate anything with the main Orbi network
  3. It is just like buying an Access Point from anybody and hanging it off the Orbi (i.e. probably a lot more expensive than an Access Point from almost any vendor, including Netgear)
  4. If a device connects to this AP, when it moves around the house there is no "hand off" coordination between this AP and the Orbi (but then maybe most devices don't move around much).
All-in-all, most people opt not to do this
Message 2 of 3
All Replies
CrimpOn
Guru
Message 2 of 3
77PALE77
Apprentice
Got it,
thanks a lot for your quick and precise answer!
Pale 77
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 7173 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
