- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Frustration
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Day
I need some guidance and would like to know if the Netgear Orbi is the best option for me.
I live in a concrete house with 3 stories, my current setup is a ASUS ROG GT AC5300 router in the middle floor using Fritz e1750 repeater to the top floor where my office is. I can only have the repeater in a certain room or else there is no reception for it. My problem is that my connection drops every now and then during my conferences and would like to know if I replace the Asus and the Fritz with a Orbi RBK50 setup if this will alleviate the situation ?
Best Regards
Marius
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem isn't the routers/extenders.
Its the cement. Cement is great at blocking wifi.
You'd be better off investing in either running ethernet through the home, trying powerline devices, or using moca adapters (ethernet over coax). If you get a hardwired connection in the home, then you can setup a mesh system but without that connection, the satellites will have the same problem the current extenders do.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Frustration
yes you are right the concrete makes it a problem, but thank you for the suggestion as I did not even think about ethernet over coax, as i have coax in every room but not ethernet (stupid for a new house). I am going to give this a go
best regards
marius
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
