- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wired devices not routing: Orbi RBR50, RBS50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
My Orbi mesh system suddenly stopped routing wired devices. I had an RBR50 with two satellites (RBS50 and RBS20) previously working well. Suddenly my wired devices stopped routing.
Current state: Factory reset all devices. RBR50 and RBS50 are configured and plugged in. I have a desktop in my basement wired into the RBS50.
- From the desktop, I can draw a dhcp ip address and I can ping the satellite, the lan side of my router ,as well as a laptop on wifi.
- The router "sees" the desktop and knows its IP address.
- I turned off "daisy chain" in advanced settings based on an Internet article I found.
- Firmware for both is v2.7.5.4
I need my desktop to connect to the internet from the basement. Any help on how to proceed is most appreciated.
https://www.reddit.com/r/orbi/comments/17s9073/wired_devices_not_routing_orbi_rbr50_rbs50/
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I solved it. I am embarressed to say, I had a killswitch process running in the background. I had to go in through the CLI and kill the process then I got right through.
Thanks for all of the help.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wired devices not routing: Orbi RBR50, RBS50
Is the desktop computer the only device which does not have internet access?
Could you open a command window and report the information about the desktop DHCP assignment?
i.e. run ipconfig /all
for the Ethernet adapter, report:
IP Address
Subnet Mask
Gateway IP
DNS IP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Yes it's a desktop running Ubuntu 22.04.3 LTS
Ifconfig =
inet 192.168.3.4
netmask 255.255.255.0
broadcast 192.168.3.255
default route = 192.168.3.1
gateway = 192.168.3.1
arp -a
I can ping the
RBR50 3.1
RBS50 3.3
But I *cannot* ping 3.2 which is the laptop connected to the wifi router that I am typing on now.
From the laptop I *can* ping
The router, satellite, and the desktop that won't route out.
No changes to desktop except I did turn the firewall off for trouble shooting. Normal rule set to deny incoming and allow outgoing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the information. What sort of computer is the laptop?
(Windows, for example, does not respond to ICMP (ping) until told to do so. Here's one article - of many.)
https://www.en-zdv.uni-mainz.de/allowing-icmp-ping-in-the-windows-firewall/
Have you tried to ping something outside the local network, such as Google DNS (8.8.8.8)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
First, thank you for the assistance.
Laptop is Windows with McAffee Ultimate running.
Firewall is Windows Defender. I enabled ICMP Echo requests:
But still no luck.
From the wired connection, I cannot ping any outside address, the external wan interface on the RBR50, or any internet FQDN or IP such as 8.8.8.8.
Router settings are:
Connected devices:
Thanks again for the assist.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad there was no issue with the Orbi. I was totally stumped.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
