- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Your connection is not private after using router admin
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am running RBR50 with connected RBS50 both running the same firmware V2.7.4.24. The firmware version is irrelevant since this problem has dogged me since getting the routers.
The issue
After everytime I use my laptop (macbook) to access the router admin, I am faced with the dreaded message.
I access through my laptop onto one of the satellite routers when using admin.
I have not been able to solve this so I have switched off the satellites which is why I bought the system in the first place.
Some forum answers talk about setting the data correctly on the system. Mine is setup to use the Netgear server so date/time is not the issue.
Some forum answers talk about specifying https instead of http, it is not this problem.
Someone please help me because I am close to throwing the routers into the trash.
I loathe this product and right now would never recommend it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Your connection is not private after using router admin
- Mark as New
- Bookmark
- Subscribe
- Permalink
The issue
This is a result of the ever increasing paranoia about security with browser makers. If you are using Apple's own browser, you are even more likely to get this sort of piffle. You are lucky that it hasn't blocked you completely, a fate that has hit other Apple users:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
I don't know how you arrived at the conclusion that this is not the problem. How did you work that out?
This is why some browsers gag.
Websites in the outside world should use https. If you are accessing things on your local network, your router's graphical user interface (GUI) for example, http is safe. But browsers are programmed to object.
Of course, if you try to access you router from the outside world, using Anywhere Access for example, https is essential, which is why that is built into the system.
User failure to understand how things work has been going on for years. So much so that Netgear added the option to set https as the preferred protocol.
In many routers, go to Advanced Setup and look in Web Services Management and the Local Management checkbox.
From time to time, someone turns up here screaming about their "broken" router when what they have done is told it to Always Use HTTPS to Access Router. Doing this blocks various things so they usually go back and this turn off.
If you reached that conclusion on the basis of that misleading error message, I fear that you may have to abandon the Internet. What you are describing is a "feature" of modern browsers and routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@microchip8 wrote:
You don't mention which browser you use.
Good point.
@Trikon mentions using a Macbook. Macs can mean Safari.
I forget to mention this in my reply. It adds another layer of complexity. Some Netgear manuals specifically warn that Safari can't be used for some functions, such as Password Recovery.
That warning isn't there for newer devices. So either Safari has changed or Netgear has worked out how to handle the issue.
But, as you say, @Trikon's beef nothing to do with the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I dont use Safari, I use Chrome.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"I don't know how you arrived at the conclusion that this is not the problem. How did you work that out?"
The problem occurs if I enter https URLs directs, I am not trying to access HTTP addresses.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"From time to time, someone turns up here screaming about their "broken" router when what they have done is told it to Always Use HTTPS to Access Router. Doing this blocks various things so they usually go back and this turn off.
If you reached that conclusion on the basis of that misleading error message, I fear that you may have to abandon the Internet. What you are describing is a "feature" of modern browsers and routers."
For you informaiton, I find these remarks vaguely condescending and rather dismissive - not really what I was expecting in a help forum. For your information, I have been working in IT since 1985 and have been an internet user since 1994. I think I can consider myself quite good at problem diagnosis, I may be a software expert but not a networking expert.
This problem only occurs immediately after logging on to the router https://10.0.0.1 to add new devices to the network via access control. It does not occur at any other time. I use the latest version of Chrome. It seems to be a wifi issue because when I connect via wired, I get access fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How many routers do you have on your network?
What is the modem/gateway/ONT that connects you to the Internet.
I ask because by default Netgear's routers allocate themselves the address 192.168.1.1. They will only go for 10.0.0.1 if they spot a possible conflict. That can happen when someone tries to add a router to a modem/router.
Do that and you can end up; with all manner of problems.
All of a sudden we have a different issue, and a different set of details.Again, the problem, appears to be in your network rather than the router.
What is it that you really want to fix?
In general, the advice from experienced users is to do as much as possible with a wired connection. Wifi is not reliable enough.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Q. What is the modem/gateway/ONT that connects you to the Internet?
A. I have full fibre to the property - some kind of fibre to Ethernet modem that I plug into the base router. NOthing there has changed.
A. My network is setup to use 10.0.0.xxx, I cant remember why. I have Access Control nailed down with registered MAC addresses for each known device. I always access the router using the 10.0.0.1 address.
I have one base router and one satellite router in operation presently. My second satellite I am not using currently. Because the satellite is in my office, I would generally use this when accessing the router admin.
Interesting, I tried the 192.16.1.1. address and then my device disconnected from the network - quite bizarre.
A. Barring the physics of wireless communication, surely the network is the router?
A. I dont want my laptop locked out of the network and internet access everytime I finsh doing router admin the add ot remove devices in the access control function. I really dont think this is unreasonable.
A. This seems like good advice. Perhaps I should also access the base router not a satellite router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We still know nothing about the equipment that delivers the Internet to your home.
"Some kind of" is not much help.
Not sure what "nothing has changed" is meant to tell us. The network attached to it has changed, if only when you play around with things. That is how the local IP address gets allocated.
A. My network is setup to use 10.0.0.xxx, I cant remember why. I have Access Control nailed down with registered MAC addresses for each known device. I always access the router using the 10.0.0.1 address.I have one base router and one satellite router in operation presently. My second satellite I am not using currently. Because the satellite is in my office, I would generally use this when accessing the router admin.
Two routers on a network is a recipe for chaos.
For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really?
"Two routers on a network is a recipe for chaos?"
Two ORBI Routers - A Base router and a satellite router - it's a mesh network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No it isn't. Mesh means satellites and routers talking to one another to manage wifi links. That communication won't work between two routers.
Maybe you have two mesh networks with the same SSID. That's not the same thing as one mesh network.
Two routers = trouble.
Regardless of their brand and claimed wifi features.
If these routers are the same model, then you best bet would be to remove one of them and stick with the satellites.
As it is, your two routers will find it impossible to coexist with the same local IP address. Perhaps that is why you have one that is not on the default 192.168.1.1. (I assume that you just made a mistake when you referred to 192.16.1.1.)
