Orbi WiFi 7 RBE973
Reply
help!
wifiblues
Luminary
help!
hi
Please help.
I am working with a RBR43 with two RBS20 satellite and a plug in satellite.
the system is certified refurbished.
here is the issue - the wifi is spotty.  when i launch the orbi app, and look at the details, it shows all the devices connected to the plug in satellite only.  One of the satellites does not show any devices connected to it.
any advice on my set up?
we live in an apartment 2000 sq feet.
do I need to perform a reset on the smaller satellites and remove the plug in?
Message 1 of 8
Accepted Solutions
Guru
Re: help!
2000sw ft maybe too small for 3 satellites. So removing the one RBS may help.
Under Advanced Tab/Advanced Settings/Wireless Settings
Message 6 of 8
All Replies
CrimpOn
Guru
Re: help!
The first step is to confirm that the satellites are sync'd to the router.
Are they?
Message 2 of 8
wifiblues
Luminary
Re: help!
I checked and the Satellites are sync'd to the router.  the light was blue.
Message 3 of 8
Guru
Re: help!
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 4 of 8
wifiblues
Luminary
Re: help!
Hi.
I’m currently running the most current firmware. Our ISP is spectrum.
I disconnected the 1 plug in Satellite that didn’t come with the RBK43 system. Just using the router and the 2 Satellites that came w the system. I also synced the satellites with the router again. This time I brought the satellites close to the router to make sure they were blue. Also, I had 1 of the satellites next to a printer and wine cooler. I think it may be fixed but I am out right now. I will check later and ask for help later. Our home is 2000 square feet apartment in Brooklyn. Neighbors have WiFi. There is 30 feet between router and satellite 1. How do you turn down the radio?
Message 5 of 8
Guru
Re: help!
Message 6 of 8
wifiblues
Luminary
Re: help!
thanks Furrye38 - i removed the plug in satellite and so far so good...
thank you!
wifiblues (no more?)
Message 7 of 8
Guru
Re: help!
Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed.
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 953 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
