- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
orbi keeps rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
my orbi reboots a few times a day.
support suggested
1. updating to the latest firmware
2. disabling my verizon wifi with these instructions -
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
i tried both and it still reboots.
the latest firmware helps and it doesnt reboot as often but still does.
any suggestions?
could it be a defective unit?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi keeps rebooting
i have the RBK50 with one satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Welcome to NETGEAR Community!
To clarify, when you say Orbi reboots, do you mean the device turns off and on?
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
the router flashes white for about a minute.
Also the logs in the admin section clears.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last update?
Is there a buit in router and wifi with the ISP modem? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
I updated to the latest one - 2.5.1.8 it seems to help. less reboots now but it still happens every few hours.
actiontec MI424WR Rev 1
i used the default - auto. Also switched it to a manual channel and neither makes a difference
yes many. I live in nyc in a large apartment complex. maybe around 10
yes
i already tried switching to AP mode and disabling the wireless on my fios modem
(this was mentioned in my first post)
is it hardware related? Is it possible i have a defective orbi router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible the system is faulty, if it continues to exhibit this problem after a reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes. after doing so its better but still reboots a few times each day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, it should be rebooting at all. I would file a support ticket with NG support and get more help and information on this. Ask about an RMA.
