Orbi WiFi 7 RBE973
Reply
orbi rbk20 router offline satelline online
valendy
Buongiorno ho recentemente acquistato un orbi rbk20 e non riesco ad installarlo correttamente.
Scaricato app, collegato al mio modem wifi telecom, seguita procedura ma poi   l'app mi dice che non rileva connessione internet (infatti mi segnala router solo connessione locale offline) mentre la mappa di rete mi segnala internet verde -  router rosso -satellite verde.
Ho il pc collegato con cavo ethernet al router orbi e sta funzionando perfettamente, un reader kindle che segnala no connessione internet ma funziona lo stesso, un paio di devices collegati che funzionano regolarmente sky non collegata e una copertura con la rete orbi della casa per nulla soddisfacente (inferiore a TPlLink che avevo in precedenza).
mah....
grazie per l'aiuto
Andrea
Message 1 of 4
Guru
Re: orbi rbk20 router offline satelline online
In inglese per favore
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
valendy
Good morning
I recently purchased an orbi rbk20 and I can not install it properly.
Downloaded app, connected to my modem wifi telecom, followed procedure but then the app tells me that it does not detect internet connection (in fact it signals to me router only local offline connection) while the network map signals me green internet - red router -green satellite.
I have the PC connected with ethernet cable to the orbi router and it is working perfectly, a kindle reader that reports no internet connection but works the same, a couple of connected devices that regularly work sky not connected and a coverage with the orbi network of the house not at all satisfactory (less than TPlLink I had previously).
Mah....
thank you for your help
Andrea
Message 3 of 4
Guru
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
There seems to be some problems regarding the Orbi app currently.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 340 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
