Orbi WiFi 7 RBE973
Reply
AX6000/RBK852 Missing Telnet access
philoouu
Luminary
Dear all,
I just bought a AX6000/RBK852 (RBK850/RBS850) with the lattest firwmare V3.2.16.6 and I need to have telnet access to be able to change Guest Network IP Range.
In the http://orbilogin.com/debug.htm it is not possible to enable Telnet access anymore.
There are many other functionnalities not availalbe in the GUI (like separate 2.4 and 5 network or rebooting the satellite...)
Is there any solution?
Thanks and Regards
Message 1 of 6
Retired_Member
Not applicable
Re: AX6000/RBK852 Missing Telnet access
Message 2 of 6
philoouu
Luminary
Thanks for coming back to me.
This is pretty heavy compared to just enabling telnet on the GUI.
Do you know if there is anything available on Mac ?
Thanks
Message 3 of 6
Retired_Member
Not applicable
Not aware of any other way to enable telnet on the new units.
Virtual machine with windows or linux will do it for you 🙂
Message 4 of 6
philoouu
Luminary
Understood. I wish the GUI would have much more options available.
I just realized the gest network was not even working through the satellite with a wired backhaul... No need to change the IP range in that case for the moment !
Hard to believe that there is bug like that for such an expensive device !
Anyway thanks a lot for your help.
Regards
Message 5 of 6
Guru
Telnet was removed a while back. No sure if it's coming back to Orbi AX.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1775 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
