- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi 753 unencrypted 5ghz network even though WPA2 security is turned on
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Everyone,
I have searched through the forum and seen other people have similar issues but briefly
1) RBK753, satellites setup with ethernet backhaul
2) from day 1, i would see messages about unsecure network depending on where I was in the house.
3) Logged into each satellite and see that the 5ghz band show no security, see below security type none
4) Have completely done a factory reset of router/satellites and tried from scratch but have the same problem
5) Someone had suggested in older models, the ability to telnet into the satellites and fix the security there via command line but looks like telnet capabilites are no longer an option to toggle on from the debug.htm page
6) Lastly, i find it interesting that the satellites show the default Orbi SSID name
Any ideas ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi 753 unencrypted 5ghz network even though WPA2 security is turned on
Also, running Router in AP mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
you may want to post your questions here:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks . just posted there.
