- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR350 - how to recover admin password without having to do factory reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
somehow my security questions seem to be wrong, though i dont remember even doing this steps when i setup the router long back.
how do i reset the system admin password now that I dont know my security answers as i need to access the system to try to make some changes which I cannot find on the app.
any suggestions will be appreciated, I couldnt find any solutions other than factory reset
- Enter the serial number of the router and click the Continue button.
A window opens requesting the answers to your security questions. - Enter the saved answers to your security questions and click the Continue button.
A window opens and displays your recovered password.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, that would be the cause. Set up the RBR using a PC and web browser and walk thru the setup wizard. This will have you input security questions. Write them down for safe keeping if needed later on. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR350 - how to recover admin password without having to do factory reset
So that process doesn't work?
I've seen soem where instead of showing the current PW, it has you enter in a new PW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it doesnt work, as it says my security answers dont match and thats it webpage goes out
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was the router setup initially with a PC and web browser as walked thru the setup wizard? You might try a full reset on the RBR and walk thru the setup wizard with a wired PC and web browser. This time be sure to write down all important information for safe keeping.
- Mark as New
- Bookmark
- Subscribe
- Permalink
was setup with the orbi app which seemed to be the simplest way to set it up hence i dont recall ever setting any admin or security questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry one more question, I dont see any guide on setting up with PC, even the netgear support site gives installation instructions by download orbi app
https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-WiFi-System?language=en_US
quite a hassle even doing the above took long 🙂 is there another source with directions how to use a PC to set it up without the orbi app.
thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Page 18 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBK352/RBK352_RBK353_UM_EN.pdf
