Orbi WiFi 7 RBE973
Reply
Will a RBS750 satellite connect to RBR50v2 router?
cojumdip
Will a RBS750 satellite connect to RBR50v2 router? I've attempted to do so using the Orbi iOS app (remote management) and after following the instructions, pressing "sync" on the newer RBS750 and waiting, its light simply turns magenta and no new satellites are found.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Will a RBS750 satellite connect to RBR50v2 router?
Orbi AX and Orbi AC are not currently compatible.
Be sure to check out the Orbi AX forum for additional information and post there.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
Message 2 of 4
cojumdip
Well that's fun that they still call it "Orbi" and don't tell you it's not compatible on the box. Will the "Wall Plugs" (RBK33) models work with my Orbi Router RBR50v2?
Message 3 of 4
Guru
Yes.
Because is called Orbi doesn't mean the different models are compatible with each other.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2073 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
