× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
RBE771/770 Firmware 10.5.13.1 is Available!
KevinLiT
NETGEAR Moderator
Hello Orbi Community,
Firmware version 10.5.13.1 is now available for installation. Manual update will be required for the devices that do not have the firmware available as an automatic update.
Bug Fixes:
  • Fixed a 2.4 GHz device connectivity issue that could occur in noise-heavy environments.
  • Fixed a WiFi 7 device connectivity issue that could affect iPhone 16 and IoT client devices.
Download Link:
RBE771: https://www.downloads.netgear.com/files/GDC/RBE770/RBE771-V10.5.13.1.zip
RBE770: https://www.downloads.netgear.com/files/GDC/RBE770/RBE770-V10.5.13.1.zip
Firmware Update Instructions:
To update the RBE771/RBE770 firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBE771.aspx#docs
Best,
Kevin
Community Team
Message 1 of 39
Barrykkli
Re: RBE771/770 Firmware 10.5.13.1 is Available!
Would there be similar firmware fix for 2.4ghz issues on 970 series which obviously suffering from same issues.
Message 2 of 39
KevinLiT
NETGEAR Moderator
Hello Barrykkli,
Welcome to the NETGEAR Community!
The current firmware for the RBE970 / RBE971 is Firmware Version 9.12.4.16 (for NA Region Only). This firmware enhances the following features:
Improved Wi-Fi and backhaul stability.
Improved system stability.
Improved client steering.
Improved speed test accuracy.
If you are located in the NA region please download that firmware to resolve network instability:
https://kb.netgear.com/000066418/RBE970-RBE971-Firmware-Version-9-12-4-16-for-NA-Region-Only
For step-by-step instructions on how to successfully manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
Best,
Kevin
Community Team
Message 3 of 39
AkWingnut
Tutor
I do not agree that this release fixes all the issues, I am experiencing random drops, loss to internet, random disconnects, network instability, my RBR850 never had the issues I am experiencing with this much more expensive RBR771.
David H
Message 4 of 39
Guru
What random drops are you experiencing?
Where are you experiencting these drops at? RBR, RBS? Connected devices?
What devices do you have connected?
What region are you located?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
David H
Message 5 of 39
AkWingnut
Tutor
Thank you for all the helpful tips, I have a current case with NetGear and are working with their engineers on fixing the issues, currently running Debugs logs for them. The last time I ran the debug it was for 3 laptops, 1 hard wired PC, a surface pro 7 and steamdeck both wired and wireless for that one. I have wired 2.5gb, WiFi 7 WiFi 6e Wifi 6 so a wide range of different devices and connections to test and run speed tests for them.
David H
Message 6 of 39
Guru
Ok, keep on with the support case then.
If you feel you wanna give more feedback to the questions presented so we might help from this side, please follow up.
Good Luck.
Message 7 of 39
AkWingnut
Tutor
What random drops are you experiencing? Random drops from Satellites and Router to the Modem, It would seem that the signal just drops and the connection to either is lost. Samsung Tab S6, Lenovo WiFi 6e Laptop, MSI Wifi 7 Laptop, MSI WiFi 6 Laptop. A pop-up shows up and says internet connection has been lost, then 2 seconds later it is restored. There are significant lag times for pages to load. Even loading SpeedTest dot net, with a 2.5gb up and 2.5gb down, connected to the RBR850 it would load super quick, however with the 771 load times can take up to 20 seconds.
Where are you experiencting these drops at? RBR, RBS? Connected devices? Both, even connected with the ethernet cat6 cable the drops are still happening.
What devices do you have connected? I have SSID for the main attached devices, IoT set to only 2.5ghz for the Cameras. I have a guest network setup for random devices.
What region are you located? NA
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended. Yes Cat 6
How many RBS are deployed? 2, at times I try just one, but my Ring doorbell WiFi strength drops considerably. Also the other cameras also drop
What is the size of your home? Sq Ft? about 1400sq, however it is very strange how it works. I have the Router and Fiber modem upstairs in the computer room, I have 1 of each Satellites located 1st floor at each end of the house. One is in the entryway, another at the backdoor.
 and satellite(s)
 and RBS
️ to begin with depending upon building materials when wired or wirelessly connected. At least 30ft, separated by floors and doors.
Does this happen with the RBS turned OFF? I have not tried that. I am thinking about turning off WiFi 7 and seeing if there is an improvement.
Does this happen with both wireless and wired devices? Yes with both. Different locations in the house, not the same area.
What channel configurations are currently set on the router? Auto
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update? Yes I reboot A LOT
Be sure to restart your network in this sequence: I have done this. I have also tried turning off IoT for about 30 minutes so the attached devices are no longer connected, rebooted the modem, rebooted the router.
Has a factory reset and setup from scratch been performed since last FW update? Yes.
Message 8 of 39
Guru
Please provide this brand and model# information.
Be sure the cable is STP and not UTP.
For that size of home the RBR and just one RBS would be needed. I'd turn OFF one RBS and leave one RBS running at 30 feet distance from the RBR. I'd even try just the RBR alone as a test.
https://youtu.be/UR0viMLISz4
What is the distance between the router and satellite(s)️? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wired or wirelessly connected. At least 30ft, separated by floors and doors. 👍
Does this happen with the RBS turned OFF? I have not tried that. I am thinking about turning off WiFi 7 and seeing if there is an improvement. WiFi 7 can't be disabled.
Try channel 1 and 40 or 11 and 48 as a test.
Message 9 of 39
AkWingnut
Tutor
Attached is an image from outside, it's not the best. However the circles on the bottom are the two Satellites the Router at the top. There are walls, doors, and floors in between each. Off photo to the left at the end of my yard after two cameras connected via 2.5ghz today total lot size is less than the allowed SF of the system
Message 10 of 39
Guru
Ya, thats a small home for having two RBS deployed. Try with one and see.
Message 11 of 39
AkWingnut
Tutor
I have, router on the top floor and Satellite on the 1st floor below the router, the Ring doorbell WiFi signal goes off the scale, from 34/41 to has high as 60, the Ring Floodlight goes from 40 to over 60.
Message 12 of 39
AkWingnut
Tutor
So recently I've tried them all, Asus BQ16 Pro, horrible their satellite would connect then disconnect, they're tech support was worthless so I returned it. Next up was the TP Link Deco BE95 awesome super fast super easy to use, however my daughters MacBook Pro couldn't see the SSID, after rebooting it would see it for a second then it would disappear. Did she research and it looks as if it was due to the auto channel selection, but I wasn't able to set it up a certain one that the MacBook could see. Next up TP Link Deco BE85 thought maybe stepping down from a newer to last year might help but it didn't at all. Then Netgear, I've been a fan of Netgear for awhile now, this is my 4th mesh system. My thing is that I hate getting stuck with something that doesn't work right. Now I'm outside the return window for this router and I've had a few firmware I've tried. I'm still working with the RnD team by running debugging for them and allowing them access to my drive so they can grab the information and ask me questions about it
David
Message 13 of 39
Guru
What is the distance between the router and the one RBS?
Message 14 of 39
AkWingnut
Tutor
I would say at least 30 feet or more, 30 feet through walls and floor, more if you go around those things.
Message 15 of 39
Guru
Ok just checking on that.
So signals are better then?
Message 16 of 39
AkWingnut
Tutor
Signals are better when using 3 only for the outside mounted cameras, I can get away with using 2 but the other cameras suffer if that makes sense
Message 17 of 39
Guru
Ya, not really meant for main use outside of the home. Maybe around 10 feet wifi converage est depeindnig on house building materials.
Message 18 of 39
AkWingnut
Tutor
The RBR850 no issues what so ever for range.
Message 19 of 39
Guru
May not be same though.
Message 20 of 39
AkWingnut
Tutor
Oh I get it, I would think though that its a better system and therefore it should cover what I need. However I am working very closely with RnD on the issue.
David H
Message 21 of 39
Guru
Hope they can get it figured out.
Message 22 of 39
wallis97
I'm having similar issues. Netgear support said it was due to double NAT with my AT&T gateway (BGW320-505). As recommended, I tried setting the AT&T gateway to IP Passthrough mode but I'm still having issues. I noticed that the Orbi RBE771 has two MAC addresses (LAN Port and Internet Port).
I configured the IP Passthrough using the MAC address that is on the back of the Orbi router (LAN Port), but I wonder if I should be using the other MAC address that shows in the Orbi config screen as "Internet Port". If someone could provide some feedback, I'd appreciate it. Thanks!
Message 23 of 39
Guru
You need to use the WAN (Internet Port) MAC address. Not the LAN MAC address.
Message 24 of 39
Bk1230
Guide
I have same/similar problems as the others on this thread. https://community.netgear.com/t5/Orbi-WiFi-7-BE-Mesh-Systems/RBE771-disconnects-constantly/m-p/24105.... Nothing works, I've updated the firmware. I got it months ago and the reliability has seemed to degrade on a daily basis, culminating in a Christmas miracle of a network system that seems to have completely trashed itself.
Message 25 of 39
Top Contributors
Discussion stats
  • 38 replies
  • 2667 views
  • 4 kudos
  • 7 in conversation
Announcements
Orbi 770 Series
