× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Satellites stop working and WiFi is offline but wired still works
Ctuck
Mine is just going offline completely. Satellites stop working and WiFi is offline but wired still works. Annoying considering returning and going another route. Less than a week old and already having issues.
Message 1 of 8
Accepted Solutions
Guru
Re: Satellites stop working and WiFi is offline but wired still works
Message 3 of 8
All Replies
Guru
Do the front LEDS turn on PINK when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Message 2 of 8
Guru
Message 3 of 8
Guru
Any progress on this?
Message 4 of 8
Ctuck
The latest update actually resolved this issue it seems like. Has not happened since they updated!
There are a couple new random little issues where internet just essentially pauses on devices and stops working but a quick off and on of wifi on the end devices fixes it. Nothing I can't deal with, but I'm sure future updates will provide more fixes!
Message 5 of 8
Guru
Should have to do that though.
Did you power OFF the system for 1 minute then back ON after the last FW update?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Message 6 of 8
Ctuck
I'll do that later today. I'll unplug the units and wait a few minutes then plug it all back in!
I think I have it off on all devices but I'll double check that as well!
Message 7 of 8
Guru
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1368 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
