- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi AX4200 Doesn't Reconnect Most Devices After Reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I own a Netgear Orbi AX4200/CBR750 which is a modem/router combo and it is running on the latest firmware. I typically have about 30-40 devices connected to the router, and it was working fine for the last few days. I just unplugged the router and moved it to a different location, and now the majority of the devices originally connected refuse to reconnect. I know the router is working, as there are about 2 devices connected via wifi right now (including the laptop I'm typing this on), but everything else refuses to connect, including the one sattelite I have for the router. I really don't want to factory reset the router if at all possible. Any suggestions? Thanks in advance!
Here is some extra info:
- I have the router in a 2800 sq ft house
- My ISP is XFinity
- The outer and sattelite are about 25-30 ft away from each other
- The model of the modem/router is the Orbi CBR750 or AX4200
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AX4200 Doesn't Reconnect Most Devices After Reboot
\30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Power OFF the RBS. Remove the RBS from the RBRs connected clients page. Power ON the RBS. Press the sync button on the RBS then on the RBR and re-sync the RBS to the RBR.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings on the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have firmware version
V3.2.18.2_1.4.14 |
I have tried the suggestions to no avail. I have my laptop now connected to the router via ethernet, and after restarting the router, my laptop is the only device connected. I have a next door neighbor using wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A factory reset and set up from scratch will be your next step.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Furry, this actually worked! But what settings can I mess with in the future so that I don't have to factory reset the router each time it power cycles?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Shouldn't have to mess with anything really.
I would make back up configuration to file for safe keeping. In case of a reset, you can just load the backup config fron file.
Hopefully this should keep working for you with out a need for reset.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
https://community.netgear.com/t5/Orbi-AX/RBK753S-update-Rock-solid-in-terms-of-speed-and-stability-s...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Unfortunately, the router was unplugged and plugged back in and only about half of the devices will actually reconnect to the router. I have tried factory resetting and restoring settings using a backup, but it didn't help the devices to connect. I have no idea what to do from here. Hopefully I won;t have to do this song and dance each time the router reboots.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try disabling AX mode on the RBR for 2.4 and 5Ghz.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I applied these settings but it didn't make an impact. One thing I have noticed, however, is that when I change some of the 2.4 or 5Ghz channels, the password for the wifi gets changed, and a bunch of random symbols get added and I have to manually change the password back to the password I want it to be. Another thing I noticed is that on my Amazon Echo Show (One of the devices not connecting), it says it can't connect due to a DCHP error, which is making me think that it is somehow unable to assign IP addresses to every device that wants to connect. My router is set to have a dynamic IP it automatically finds from the ISP, and the same is true for the DNS. Should I change these settings as well? I have attached a picture to show the settings in question.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser are you using? Try MS Edge, FireFox or Opera and see if you notice this same issue of values changing...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
The values for the password do not change in Microsoft Edge, so I will continue to use that. I have tried changing the channel for 2.4 Ghz and 5 Ghz, but about half of the devices still refuse to connect to the wifi. I am still getting the DHCP error on the smart speaker, which is making me think that there could be a problem with the DHCP function on the router. What I have also observed is that when I change a setting, the number of connected devices will jump up to 20-30, but after a few minutes, most of those devices will disconnect automatically, leaving me with about 10 devices connected. It will jump between having about 21 devices to having 10 devices connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try disabling AX mode on the CBR750 as well...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There maybe two check boxes on the Basic tab/Wireless setting page on the CBR750...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, I changed these settings and the majority of devices reconnected fine(including my phone and Amazon smart speakers), but I then unplugged and replugged the router, and now there are things not reconnecting such as smart switches, my cellphone, and the Amazon smart speakers. Those speakers are giving the same DHCP error as before. The router has to be unplugged and replugged a few times because there is work being done at my house. I just don't want to have to factory reset the router again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How often is the CBR being unpluged then back on or when the power goes out? Time in between power outages?
I recommend that you save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is getting reset only about once every few hours, but typically, simply rebooting the router shouldn't cause the router to malfunction? I do have a backup of the configuration.
- Mark as New
- Bookmark
- Subscribe
- Permalink
