Orbi WiFi 7 RBE973
Reply
Any Plans for ORBI Firmware Upgrade for guests on WiFi to see each other WITHOUT accessing the LAN?
jmchez
Tutor
Are there plans for a firmware upgrade to the RBR50 firmware to allow guest to see ach other wihtout having acess to the main Lan?
If the answer is no because this is a limitation of the product, I will start to see how to recoup my $300 dollars and sell the ORBI set. I hope that it doesn't come to that.
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Any Plans for ORBI Firmware Upgrade for guests on WiFi to see each other WITHOUT accessing th...
Hello Jmchez
Can you be a little more specific what you are wanting to do with the guest network?
DarrenM
Message 2 of 4
richpjr
Star
Re: Any Plans for ORBI Firmware Upgrade for guests on WiFi to see each other WITHOUT accessing the L
The Velop also has the same restriction.
Message 3 of 4
this actually doesnt make sense as you wouldnt want guest access to the lan or each other , the whole concept of guest isolation and guest wifi is built on this in most domestic wifi
in more soho / prosumer type gear you can use vlan and do what ever you want but this features is found on a different class of gear
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2978 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
