Orbi WiFi 7 RBE973
Reply
Can I connect other lan devices into the same switch used for orbi RBK50 ethernet backhaul
GAP1
Can I connect other LAN devices into the same switch used for Orbi the Ethernet backhaul ?? Orbi is in router mode with 2 satellites. Orbi router wan is wired to the modem and one of the LAN ports is wired to a large switch with both satellites wired to the switch.  Thus, can I connect other LAN devices to the same switch used for Orbi the Ethernet backhaul?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Can I connect other lan devices into the same switch used for orbi RBK50 ethernet backhaul
Yes you should be able to do this.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 468 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
