Orbi WiFi 7 RBE973
Reply
Disable DHCP on the ORBI
Michael512
Follower
I would like to add a IoT firewall (CUJO) to my network, however they require I disable  DHCP on the ORBI. How do I do that? Or is it even possible? I have the  MAC Addr for the CUJO.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 7
rhester72
Virtuoso
Re: Disable DHCP on the ORBI
You can put it into AP mode, which will disable both DHCP and DNS, but that assumes you have some sort of router/edge device sitting in front of it on your network.  At that point, it will act as nothing but a WiFi bridge to your network, assuming all other services are provided by another device.
Rodney
Message 2 of 7
before you consider the cujo you might just want to read
http://www.smallnetbuilder.com/lanwan/lanwan-reviews/33018-cujo-smart-internet-security-firewall-rev...
being fully could based
CUJO costs $99, which includes a 180 day trial license. After that, you need to pony up $8.99 / month, $26 for three months, $49 for six months or $80 for a year of service. If you're a true CUJO believer, you can opt for a lifetime subscription for $800.
so unless you are willing to fork out $800 for the lifetime subscription they gave you trapped
the dual nat issues are also a concern
i just think its prob overkill for a home based solution and expensive and cloud based , if you are concerned by security why would you want your data being read or stored on the cloud
pete
Message 3 of 7
dpdurst
Luminary
From what I see just untick the box that says use DHCP and your then all static assignments. Seems pretty straight forward on the Orbi
Message 4 of 7
this aproach would see anything connected behind the orbi would have to deal with dual nat , sure it may work for basic stuff but things that need 2 way communications like games and torrents etc etc would have issues
Message 5 of 7
dpdurst
Luminary
I would agree but from I see with the Cujo it's only handing out DHCP, say nothing about being a router so if that is the case there is no double nat happening. If in fact it is a router then your right of course it would be a double nat going on
Message 6 of 7
if its handling firewall duties it has to be a nat and router as a firewall is the front door to the nat and thus there will be double nat
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 17557 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
