- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Firmware V2.1.1.16 auto update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware V2.1.1.16 auto update
Please can you tell me what firmware was in the begining when we first purchased this RBK50 i mean factory default firmware? i wants to downgrade to . actually my speed was 300 mb all over in my home since i upgrade to lastest and latest its become slow slow and slow..
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't recall the original firmware rev with specificity, but it was a v1.x release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
so it is same prcedure to downgrade to v1? like we upload lates one?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep, it works the same exact way. I rolled back from 2.1.1.16 to 2.0.0.17 to 1.12.0.18 to 1.11.0.20 over a week ago to get stability back into my setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok i tried now to downgrade to v1. will test all again and if its work will wait to checked the stable orignal firmware comes. otherwise will keep the factory default
- Mark as New
- Bookmark
- Subscribe
- Permalink
The other thing you'll need to make sure you do if you do rollback is that you disable automatic updates.
You can follow this post, which worked for me: https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/m-p/1323973/highlight/true#M103...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I solved my problem.
The root cause is the truncation of the WiFi password after the "$" -- in my case, the first character.
The router passes this on to the satellites and the satellites then shut down WiFi for some reason.
I reinstalled FW 2.1.1.16 in the router and then, using an ethernet connection, the satellites. I then reset the satellites to factory default, which reenabled WiFi. Next, I selected a WiFi password without special characters. I then successfully resynced the satellites.
Finally, I am reprogramming all of my household appliances to the new WiFi password, which is a real pain.
Netgear engineers, please take notice: I am an engineer; this is not a friendly bug for most consumers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
please can you help my 3 question.
can i add on any satellite to my RBK50. . Looking to buy rbsw60 wall connectec?
and i am happy with roll back my firmware to .74. all works fine all nearly 260-280 mbsout of 300mbs. and last i tried beta firmare last one. but not happy, are they released final virsion of stable. firmware with backhual.. and last. i dont know how do i create my own new thread. when ever i tried erros comes highlighted error correct. i did but not sucess to put my own tread on this forms please help thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can add any model satellite to your RBK50.
DarrenM
- « Previous
- Next »
