- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Glad I left the old system up
- Mark as New
- Bookmark
- Subscribe
- Permalink
When using the Orbi network and trying to get access to a email link or any other link I get error code 401(not found). when I switch back to the old system no problem.
If its bit defender, how do I shut it off?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Glad I left the old system up
Which orbi system?
What firmware are you running?
What modem are you connected to?
Have you just setup this system (aka is it new)?
Are you able to access the gui via a browser?
You can go to netgear.com/support/ type in your actual model number and have access to troubleshooting, install manuals, install videos, the actual manual. Its a great resource if you're just setting up the system.
If its new, you also have access to 90 days of free support. You'd click mynetgear at the top of the page here, register an account, then your device, and from there you can access support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's new registered 1/2/20 and is a RBR50. It's connected to a Netgear AC1750 modem. It's a router motem combo and it still works fine.
The orbi must be blocking thus getting error code 401 or page not found. When I switch back to my old system all works fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jhandy wrote:If its bit defender, how do I shut it off?
Did you activate Armor (Bitdefender) during the setup? (I always said, "no") I have heard of only two ways to turn off Armor (1) a new setup (ugh), or (2) open the Orbi "app" (not the web interface), scroll down to "Security", open that and there is an option to turn it off. I have not done this, as I never turned it on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jhandy wrote:It's new registered 1/2/20 and is a RBR50. It's connected to a Netgear AC1750 modem. It's a router motem combo and it still works fine.
Netgear ac1750 is a speed not a model number.
Regardless, if you're using a modem router combo and an orbi and the orbi is running in router mode, you're in a double nat which can give you the error your getting.
https://kb.netgear.com/30186/What-is-Double-NAT
your 2 easiest options are to place the combo device in modem only mode or to place the orbi in AP mode.
