Orbi WiFi 7 RBE973
Reply
Losing wifi when internet goes offline with RBK50
Enterprisemedia
Follower
Hi folks
We get a lot of internet dropouts at our place.
Our RBK50 goes totally offline when this happens. Now, of course, we don’t expect any internet connectivity when that happens, but it takes offlone all our local devices so, for example, we cant turn smart switches on and off etc
Any advice on how to fix this issue?
TIA
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
CrimpOn
Guru
Re: Losing wifi when internet goes offline with RBK50
Most smart switches are controlled through "the Cloud".  i.e. the smartphone app connects to the cloud service which sends a command to the switch.  No Internet = No Control.  I verified this by looking at the "Open Connections" on the Orbi.  Each of my smart switches keeps a connection open to the Internet (typically to an IP that traces back to Amazon Web Services).
My Nest thermostat is the same way.  Open the Nest app to change temperature and the command comes from the Cloud.
Message 2 of 5
JoeM845
Luminary
@Enterprisemedia wrote:
Hi folks
TIA
I presume that you mention smart switches as an example rather than the only devices that go down. Also presume that some of these devices do not have a suspect switch between you and the device. Some smart switches may require Internet access to function or configure. I don't know. I would never buy one.
My RBK50 (AP, fw 2.1.2.210) does not behave this way. I lost Internet this AM - actually a switch between my router and the modem. The RBR50 showed the magenta top lights. I was able to connect to devices on my side of the failed switch - including most of my LAN. I did not lose communication with any device on my side of the failed switch. I power cycled the failed switch and full functionality was restored. I did not have to touch the Orbi or any other device on the network.
Note that my RBR50 is in AP mode. There are some behavioral differences that you might not expect. One could be reaction to loss of the Internet. I don't know.
Message 3 of 5
ekhalil
Master
The bahavior you described is the same whether Orbi is in AP or Router Modes. Loss of internet should not affect the communication between your devices that are attached to the LAN.
Message 4 of 5
Guru
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Hi folks
TIA
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1254 views
  • 3 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
