- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nat loopback
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nat loopback
Hi,
I've found a thread about nat loopback but no answer. It looks like nat loopback is not working. I've configured port forwarding which is working perfect when using data on phone of from another network.
When i'm trying to use the same dns name and port from within my home network I can't connect to my webapp.
Is this a known issue(or feature) or do I have to change some settings?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nat loopback
Its possiblet that loop back isn't supported on Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nat loopback
@Sennevds wrote:It looks like nat loopback is not working. I've configured port forwarding which is working perfect when using data on phone of from another network.
Netgear has a web site (dated August, 2018) showing which router models support NAT loopback:
https://kb.netgear.com/000049578/NETGEAR-Router-support-for-NAT-Loopback
None of the Orbi models appear on the list. Since Orbi is based on OpenWRT and the Nighthawk line is not, my guess is that Orbi does not support NAT loopback.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nat loopback
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nat loopback
Can find you a router that supports loopback then disable it's WiFi on that router and configure Orbi for AP mode and use as your main wireless system.
Good Luck.
