jallison86's avatar
jallison86
No LED when powering up
Came home today to find no Wi-fi from my Orbi system. The base unit appears inert -- when I cycle power no LED lights come on on the top. The power LED is on, so the unit is receiving power. Tried using a paper clip to reset but the power light never changes to amber. Any thoughts?
Thanks.
- Jeff
  • FURRYe38's avatar
    How long did you hold in the reset button? Hold it for 15 seconds at least until the top LED comes on Yellowish/Orange color. When you release the reset button, the top LED should start to blink WHITE.
    If you don't see any of this, I would contact NG support and ask for an RMA.
    • jallison86's avatar
      jallison86
      I've held the reset button for 30+ seconds. I tried holding it down as I cycled power. Nothing. I purchased this unit in April, 2017, just over one year ago. Netgear does not appear to offer any sort of support beyond the $49.99 option. Given the price of the system I certainly hope there is some recourse here beyond simply, "it's dead, throw it away."
      • FURRYe38's avatar
        Might have someone check the power adapter voltage and amps to make sure they are ok. Some adapters can go bad.
        You might contact AmitR or DarrenM in a PM and see what options you have...
  • FURRYe38's avatar
    Hope you can get someting going. Let us know how it turns out.
      jallison86
      Finally got a chance to check the power supply output. It's right on spec -- 12v @ 3.5A. So unfortunately that's not it. Looks like I'm the owner of two very expensive bricks.
      • FURRYe38's avatar
        I would contact NG support or ChristineT and ask for help and information on this. See if an RMA is available to you. Let us know if you find out anything.
