Orbi WiFi 7 RBE973
Reply
Orbi 3000 is connected and wont stream Netflix but everything works
Denpet1960
Follower
My Orbi 3000 is connected but wont stream Netflix on my Hisense television but it streams You Tube, can someone let me know what the problem is, thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
ekhalil
Master
Re: Orbi 3000 is connected and wont stream Netflix but everything works
  1. How is your TV attached to Orbi, wired or wireless?
  2. If wireless, then in the Orbi app, can you please check the radio link quality and link rate as reported by the TV to Orbi. You can see this information in Attached Devices in the Orbi app or the Genie app.
Message 2 of 4
ammcleod01
Playstation network wont stay connected, so can't access Netflix
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 3 of 4
Guru
Is the Orbi system operating in Router or AP mode?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1734 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
