Orbi WiFi 7 RBE973
Reply
Orbi CBR750 & TunnelBroker IPv6 Setup
shotah
Follower
How to configure IPv6 using tunnelbroker.net? https://tunnelbroker.net/
I can get it to work with other routers such as llinksys and eero, but I cannot get it to work with Orbi CBR750.
I looked at https://community.netgear.com/t5/General-WiFi-Routers-Non/How-to-configure-IPv6-using-tunnelbroker-n..., but I do not see an option to enable 6to4 tunnel at http://192.168.1.1.
Please let me know if 6 to 4 tunnel is supported on CBR750. If so, how can I enable it?
Message 1 of 4
CrimpOn
Guru
Re: Orbi CBR750 & TunnelBroker IPv6 Setup
A lot has happened since those instructions from 2012 for the WNDR4500.  Orbi's support IPv6 natively, as do many ISP's.
A brief scan of their FAQ and forum did not turn up any mention of Orbi routers.
Just as a side note, the default Orbi configuration is not to respond to external ICMP, which is a requirement for TunnelBroker.
(This is an option that can be changed.)
Orbi may not be the product for you.
Message 2 of 4
Guru
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
Message 3 of 4
Guru
Any progress on this?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1209 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
