- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK50 - WIFI drop outs constantly
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ever since replacing my Asus RTAC87U with the RBR50 I have been having constant Wifi drop outs on all devices. I have observed on some devices including my S10+ and a Samsung Galaxy Tablet showing the Wifi Icon as still connected to the Orbi but without internet. Now when this occurs I jump onto my desktop to check if there is an internet connection, which after checking shows the ethernet device will full speed. I try and run speed tests on the devices including my S10 and I get Ping: 41ms, Jitter 457ms, Download 0.04 and Upload 0.00Mbps with the speedtest app.
Using latest firmware 2.5.1.8
Also my satelite is connected via Wired Backhaul through a POE Switch.
ROUTER --> POE SWITCH/GIGABIT SWITCH --> SATELITE. (Now was wondering if this may be the cause of the issue due to it going through the GIGABIT SWITCH?).
I have used network analyser app to find the best Channel for my 2.4ghz and 5ghz channels that my neighbours are not using also.
I am at a loss as to what to do to fix this issue. The Asus AC87U was flawless and never had wifi drop outs.
I have tried disabling different settings including MU-MIMO, WMM, and 20/40 Coexistence, Beam foaming. All seem to have the same issue that happens intermittently. Sometimes in one room I can go from 340mbps connection speed down to 32mbps. Extremely unreliable.
Disabling (WMM) causes my wifi to be connected at only 54Mbps.
I think my only option is to try and use wireless backhaul to see if that fixes my problem. Any recommendations? I have attached my settings. Am considering selling this and going back to a singular device with no Mesh. Hopefully I can resolve this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK50 - WIFI drop outs constantly
What is the Mfr and model# of the ethernet switch in the configuration? If this is a managed switch, try the RBS directly connected to the RBR, by passing this switch. IGMP should be disabled on managed switches and use of "Green Ethernet" featured switches is not recommended.
Beamforming and MIMO(MIMO may or maynot be needed) and WMM should always be enabled. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have tried all options as mentioned. Similar issue to https://community.netgear.com/t5/Orbi/Orbi-RBR50v2-WiFi-Connection-Drops-on-Smartphone/m-p/1854753#M...
Have tried everything. Considering moving back to ASUS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would be nice if you gave feed back next time to the questions presented so we get more of a picture of what you have goign on there. Possible you just have a faulty unit. Not everyone has this problem. Contact NG support and ask about an RMA.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your having similar problems and have tried everything, you'll need to make contact with NG support to continue the support effort. Not everyone has problems with there wifi. Some have had problem units being faulty in which NG has sent them new units. Something to ask NG support about:
https://www.netgear.com/support/#
Can try Voxels FW as well:
Good Luck.
@JimboNZ wrote:
Exactly the same issues. Been trying everything - different switch configs, MIMO, beam forming, DHCP etc. You name it... Clearly an underlying issue with these units. These posts have been going for ever. What's Netgear going to do about it????
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's the score on this update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've a similar problem with my S9+ and Laptop. The WiFi /VOIP calls keep dropping. esp moving from one room to another. There is no drop visibily on the WiFi itself and no issues seen with the static devices. If I disable WiFi, call on mobile 4G network functions without a problem. Appreciate if there are good troubleshooting guidelines to solve this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Sundararamany wrote:I've a similar problem with my S9+ and Laptop. The WiFi /VOIP calls keep dropping. esp moving from one room to another. There is no drop visibily on the WiFi itself and no issues seen with the static devices. If I disable WiFi, call on mobile 4G network functions without a problem. Appreciate if there are good troubleshooting guidelines to solve this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I wanted to add to this thread. I purchased the RBK50 with the acompanying sattlite and my setup is (In Australia) a Fibre 100M/20M service which connects to my carrier NTU and then my RBK50 Router. I have setup with approximately 10+ devices to my wireless network and when it is not dropping out, its been a life changer. But like many I am experiencing intermittent wireless drop outs. My setup is in a single level home with approximately 160 sqmetre living area and I have the sattelit at approx the same recommended distance. It has been 5 days and with the intermittent drop outs have been inconvenient. Steps taken:
Firstly I am running the fimware V 2.5.1.16 which is the latest available for Australia
1. factory reset
2. unplugged all cables and reconnected
3. contacted netgear support and they advised to change the wireless 5GHz from 36 to 40 and then to keep changing this settings until the drop outs resolved. Its current aat 48 and after calling back to neatgear support they have emailed the case to suggest that the RBK50 units is faulty and recommended I have it replaced. Iam convinced that there was more that could be troubleshooted, and will exercise that if all my options get exhausted.
But I wanted to share that I have performed the follow as you have suggested of
1. change 2.4ghz channel from auto to 1
2. disabled 20/40Mhz co-existence
3. enabled BEAMFORMING
I've applied and have rebooted. Are there any other suggestions should this not work?
I will update on status - Im crossing my fingers that this will work
- Mark as New
- Bookmark
- Subscribe
- Permalink
@my_coron wrote:Hi,
1. factory reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok so an update from yesterday. Firstly to answer the distance from Route to Sattelite. It is approximately 55 feet. The sattelite light is blue blue on reboots. Secondly I have approximately 7 other networks.
Ok the bad news first. After making those changes described in my first post whilst the wireless connection was on for much longer (approximately 5 hours) it eventually dropped.
So change follow changes were made on the Orbi in firmware:
2.4GHz Channel - 01 and then to 06 after another drop out
5GHz Channel: left on 48
Both 2.4GHz and 5GHz preamble modes to both Short Preamble config
Disabled Dasiy Chain Mode
So my current settings before I went to bed are now as all checked-boxed recommended by Furrye38 and include settings of:
SSID Wireless
2.4GHz: 11
5GHz: 40
One thing to note - Armor is still activate as I have for the BitDefender subscription (after some challenges in getting the licenses activated, nonetheless I wanted to commend also the BitDefender service desk in Romania who were patient and supportive to assist)
I will monitor and update all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Community,
Unfortunately this morning the intermittent drops out have continued.
I have now disabled NetGear Armour (I paid for the NetGear/BitDefender subscription) and wil wait and see.
Iam extremely disappointed with this experience so far. I purchased this on the recommendation of a colleague but it has been nothing short of wanting to launch the RBK50 router and sattelite out the window.
Does the suporting community have any suggestions should disabling Armour not resolve my intermittent drop out issues @FURRYe38 @Marky-P ? Should I look to take to replace it as per the incident case with Netgear support? I didnt think they troubleshooted in length hence Ive gone down the path on the recommended router config changes.
If I there is nothing else if the disabling of netgear armour not resolve my intermittent drop out issues I will probably look to replace with a new orbi rbk50 and if it continues to drop out after and should it contnue to drop out after that, surely its time to give up. This has been such a frustrating experience and I can now see alot of customer disassitsfaction on this product which I probably should have done research and taken note.
But when you make a small investment at this price tag, you expect the performance and importantly the stability as advertised. Extremely disappointed thus far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you disable Armor thru it's app or did you do a full factory reset and setup from scratch then do not enable Armor?
@my_coron wrote:It has dropped out again with the NetGear Armour disabled.
I've followed all recommendations suggested by @FURRYe38
Can anyone please assist here for any other suggestions for I go and return the device?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seen it were even though users diable Armor in the Armor app, the service seem to still be running and sometimes have caused problems. Users have mentioned that doing a reset on the RBR and after the setup wizard completes, users don't re-enable Armor here, then have better experiences.
If after this, the orbi still has problems, I would seek to return the unit or ask NG for additional help and or a RMA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure - I've done that now and wait and see. Ive factory resetted and installed again and disabled armour from the setup.
If the wireless drops I'll look to get it replaced.
This has been a hugely frustrating experienced.
Ive spent all weekend making these changes in hope the orbi's would stay connected.
Will update on result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Understand the frustrations, these things are not easy to setup nor troubleshoot. Hopefully something will get better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And my only other frustration is that if disabling Armor is a troubleshooting known, why isnt it described in instructions? Naturally with the hype of already purchased the subscription for BitFender.
Anyhow let's wait and see on the WiFi stability. As mentioned have follow @FURRYe38 all your instructions to date and will keep posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It has dropped out again. I will look to replace this as advised. And of course its currenetly out of stock in my state so ill need to wait when it is re-stocked. This has been one of the most frustrating experiences and Il look to update and document a google review about this journey to warn of other users.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
an update- final one I hope
So the RBK50's are out of stock from the orginal place I purchased from.
Bit the bullet and purchased the RBK23 with x 2 sattelites.
Needless to say little effort setting up and has not dropped out ONCE
Outside of me enabling MU-MIMO & BEAMINGFORMING
runs like a dream.... until the next drop out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible your 50 series could be faulty. Something to contact NG support about and see if they can help you with that system. Ask about an RMA.
Not sure if I mentioned Voxels FW as well...Something to try on the 50 series if you choose to do so:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
You can revert back to stock FW if it doesn't work out for you.
Let us know if the 20 series does the same thing or not. Hopefully not.
